Anyone running a trank trigger on their LT1?
Thank you very much,
RJ
). Figured I'd build a custom billet cover for the opti, ditching the cap/rotor. If I go this route and it works good then I might get the new MSD Opti with the bigger bearing, better eye sensor and just run the billet cover on that with the LTCC setup. Always wanted to do the crab style dist setup, would love to know if you can pull the crab out with out dropping the engine.
You stated you had your MSD distributor modified. I take it you had a cam sensor installed so you can run Sequential. If so, who modified it for you. i have a front mount MSD and would like to have a cam sensor installed.
BTW, another good reason to run sequential is when running large injectors to help with the idle quality. I have 160lbs. injectors on my 598 and want to run the sequential for that purpose. Other than that I'd run the batch since i't a drag car.
-Dave
