Head porting experts here
Old Mar 19, 2006 | 03:22 PM
radd's Avatar
Default Head porting experts here
I just ported out one of my heads and had a few
oopps's
here are some pics nothing major that i can tell but i would like to know if they are safe to throw on the car or do i need to get the head fixed?
http://radd.zeroproof.com/Camaropics...roheadsported/
fixed link
here are all the pics ^^^
Old Mar 19, 2006 | 03:57 PM
96capricemgr's Avatar
Commented on the other board but basically it is the head gasket sealing area nick and the valveseat nick that worry me, the intake port nicks could seal with a little silicon but since you need to bring them to a machine shop anyway get all the mating surfaces done and a valvejob.
Old Mar 19, 2006 | 05:16 PM
MrBill97396's Avatar
those little nicks arent going to really do anything as far as sealing up. I would highly suggest you get a valve job and have them checked out by a professional. But be ready for critics
Old Mar 19, 2006 | 06:16 PM
Did you look at the pictures? Like the one where the nicks run from the water jacket hole into the combustion ring? Could be argues a slight leak between intake ports is unimportant but water into the cylinder is a HUGE problem.
Old Mar 19, 2006 | 11:20 PM
SStrokerAce's Avatar
Same thought here.
I would mill them anyways to get them back to straight.
Bret
Old Mar 19, 2006 | 11:31 PM
96SCTA's Avatar
Get them milled.
Old May 8, 2006 | 12:35 PM
radd's Avatar
A few ppl had asked to see the results from my self head port job.
cc305 car vs my 224 230 cam + ported heads.
Raced him before heads and only pulled 1/2 a car
im right lane on the right in the end
http://radd.zeroproof.com/Videos/Cruise050606(2).WMV
Old May 8, 2006 | 01:29 PM
travie319's Avatar
Good Job.....
You Just Saved Alot Of Money On A Stock Head....that Probably Flow What Those Other Piece Of **** Heads That Cost Alot More Flow....
Old May 8, 2006 | 01:37 PM
Captainofiron's Avatar
I dont see any pictures???
Old May 8, 2006 | 01:40 PM
radd's Avatar
i changed the directory on the photos of the heads
here they are
Old May 8, 2006 | 02:23 PM
Very doubtful !!! There is more to it than just flow numbers alot more.
But nice race and nice steal of the move also
Old May 8, 2006 | 02:28 PM
radd's Avatar
i didn't jump..... he honked and it was a even jump. hes been racing his auto for several years and for 2 years we have been nose and nose.
Old May 8, 2006 | 02:35 PM
Cool deal, is there any N20 on the car ? yours that is ?
Old May 8, 2006 | 02:42 PM
radd's Avatar
yes i have a 150 shot waiting for the window switch to come in
Old May 8, 2006 | 04:34 PM
Okay cool, what is the other car running ? Post up some ET's when you get them.
Old May 8, 2006 | 04:46 PM
slowmofo's Avatar
Radd--- What kinnda of exhaust are you running.
your car sounds real good.
In the very end of the video is when you can hear it, kinnda gets drowned out buy the camera car as you pull away .
Old May 8, 2006 | 05:03 PM
radd's Avatar
other car ran 8.1 @89 mph (think that was the time) with a 1.8 60 ft
Thanks for the compliment on the exhaust. i have pacesetter 1 7/8 long tube headers into a 3 " collector to a 3" y pipe into a cutout and out the back no muffler no cats.
Old May 8, 2006 | 05:05 PM
Looks like a ok job, you might need to get the flanges milled because of the damage to the intake side, as far as the valve seats you are going to need to get a valve job, but you did a pretty good job,
you could probably go further on the combustion chamber, a little tip when you are doing the chamber is to put some old valves in the seats that way you dont damage or groove them accidentally.
Old May 8, 2006 | 05:11 PM
radd's Avatar
i fixed everything and had the surfaced mated and used grinding compound on all the valves
Old May 8, 2006 | 06:38 PM
The only problem I have with just lapping the valves is that it is not 100% effective in MOST cases. Not saying in yours, did you have the seats and valves checked to make sure there is no leaks ? I really hope I am not coming off as an *** I am just curious. I tried to just lap the valves on some heads I worked on but they did not mate up perfect and air was coming thru.
IMO I wouldn't do to much to the chambers maybe just cartridge roll it, but not to much as to changing the ratio. I agree though all in all not to bad for a home job, as long as the flow characteristics are good and the numbers do not fall off your in the clear.
