Cam gears Q??
I was thinking of replacing the timing chain with a new one and that about it but a friend told me that i need to change them to after market one's.
so what do i do?
I could be wrong here but I thought the 94-f-body with it's non-vented opti got a different cam nose than the vented opti and the HOT was made for vented? Hopefully someone else can comment on this.
Since you have a 94, you will also need to shorten the dowl pin on your hot cam for a non-vented opti style. I would reccommend changing to timing chain set with an oem one since you are there doing the work. If you want to use the LT4 set, you would have to convert to the vented style opti, which requires you the change the timing cover, new opti (vented), search for a write up on it. Check this web site out. Great info on How To. ShoeBox
so, do i use the OEM cam gears and timing chane?
and placing an other order for parts and waiting for it to arrive from the states is an other headache that i can spare.
the shipping rates are really inflated now.
