Ignition Problem: Engine has no spark.........
Old Mar 19, 2006 | 11:30 PM
transam5.7lt1's Avatar
Default Ignition Problem: Engine has no spark.........
Here's the situation: 1994 Pontiac Trans Am, 5.7L, 4L60E.
Car was running well, I was just cruising last night without problems, I went home and parked it, the car has been on the same spot since last night, I went to fire it up today and it just wouldn't start. Engine has no spark, I took off ignition module and coil to get them tested... both tested good. Fuses are ok, what else could trigger no spark??????? Any help would be greatly appreciated.
Old Mar 19, 2006 | 11:37 PM
96SCTA's Avatar
Are u getting spark at the coil. Pull the one side off the opit and have some one crank it for u to see if u get spark( u will need to ground it to the block, just put a plug in the boot and hold it near the block/head.
Old Mar 19, 2006 | 11:38 PM
I will check that tomorrow, but, what if it doesn't have spark at the coil?
Old Mar 19, 2006 | 11:46 PM
96SCTA's Avatar
ok if it does have spark at the coil then pull a spark plug out and keep the wire going to it atacked and crank it and see it it sparks . Try it with a few, If u have spark at the coil and no spark at the plugs then ur opti spark is bad.
If u Have no spark at the coil, and ur ingnition modulal is fine, and then it woudl have to be an ignition relay. ( CHECK A HANES MANUAL FOR HELP WITH THAT) Make sure u check all the wires to the coil and the modual also. the manuel will tell u how ot check voltage at the wires to the coil.
My guess is that its your opti spark. You dont have an aftermarket ignition system do u? Is the motor truning over when u try to start it?
Old Mar 19, 2006 | 11:55 PM
I replaced cap and rotor about 6 months ago, I installed that kit form MSD..... it was running great, until today. Could it be a bad optical sensor?
Old Mar 20, 2006 | 12:05 AM
96SCTA's Avatar
Yeah, Well put it this way i put a brand new opti in when i did my motor build up and it lasted 16 miles. It shreaded itself, I then got the rebuild kit for like 100 dollars and made some of my own improvements when i had it apart. Worked fine after that.
Old Mar 20, 2006 | 12:07 AM
96SCTA's Avatar
buy the way i love ur car. Thats how my baby started out , Same exact as yours, use to be white also
Old Mar 20, 2006 | 12:12 AM
Thanks for the compliments, I just went and check for spark at the coil..... it doesn't have spark at the coil nor plugs........ is there a relay for the ignition or opti???
Old Mar 20, 2006 | 12:15 AM
96SCTA's Avatar
I have not been under the hood of our cars of about 6 months now, But if i remember there is an igniton relay in that little black box on the right side of the car buy they wheel well (driver side) near abs crap. My car is a 96 so not sure if urs is the same
Old Mar 20, 2006 | 12:19 AM
96SCTA's Avatar
im not 100 pct sure about the relay,of its location
Old Mar 20, 2006 | 12:28 AM
Well, it has been enough for today, I'll call it a day. I will be at it tomorrow, by the way, thanks for all the help, you have a nice looking car, love the real flames on the car.
Old Mar 20, 2006 | 12:39 AM
96SCTA's Avatar
Thanks, Hope u find the problem, I know how much of a pain in the butt it can be,
Old Mar 20, 2006 | 06:54 PM
Anyone with more help........
Old Mar 20, 2006 | 07:05 PM
-PEPE-'s Avatar
96SCTA nailed it on the testing, if you don't have spark @coil using the method he described I would then use a multitester on the coil. If you are running the stocker I believe it's 8000 ohms (test each receptor (4 on a 96-97) by holding one lead on the coil output and other lead in each receptacle. If you have less than 8000 ohms it could be a bad coil (first check the spark test). If your running an MSD Blaster Coil it should test to 5600 ohms, my friends tested to 5400 and it was indeed bad, put a new coil on and shazam it ran fine.
Not saying this is your problem but a further testing of your coil is all.
Old Mar 20, 2006 | 07:34 PM
silverlt1ss's Avatar
if fuses are ok and relays are ok ... i would say module. they do act funny when warm/ cold.. my 86 monte carlo ss did the same thing. drove it home parked it, next day. crank and crank and crank....no spark, replaced module bingo fired right up
Old Mar 20, 2006 | 07:37 PM
But I took module to get it tested at Advance, and it tested good......
Old Mar 20, 2006 | 11:25 PM
I fixed it!!!! and its running like a champ once again!!!!!! I am very thankful to those that bothered to post, thanks once more for all your inputs!
