Axle Question
Old Mar 20, 2006 | 08:47 PM
Shackleford's Avatar
Default Axle Question
I had to replace the passenger side rear axle in 2004. From what I remember, it's a little longer than the driver side. I hear clanking and what not from that side at low speeds, such as when I'm cruising a parking lot. I jacked up the rear of the car and could pull in and out the driver side wheel/axle just a very little bit. I could pull in and out the passenger side wheel/axle noticeably more. Will buying a different axle shaft of idential size to the driver side correct this? Thanks.
