first time tuning up an LT1...questions
Also, what plug wires? I want them to be able to fit in the factory wire holders, so those big Thundervolt 10.4's are probably out of the question. Will 8.5mm wires fit in the factory holders? If they do, I was thinking a set of MSD Superconductors, as I am happy with mine. I am probably going with a set of NGK TR55's, just like I run in my car, is there a better plug for the LT1 that you recommend I use instead? WHat gap do I run them at?
The car is completely stock.....
thanks,
Paul
You see a room full of about 40 wild, feral cats.
Your job is to put them in individual boxes for transportation to the local animal shelter. You work all afternoon, you're completely scratched up, frustrated, and still can't get to that last cat that's hidden way off in the corner.
That's what changing plugs and wires on a LT1 is like.
The factory routing for the wires on the passenger's side is the worst. Forget about using the factory loom on that side. Going under the power steering pump sucks. Just run them behind the bracket (immediately outside the optispark) and you'll be fine. Definitely bring along some good zip ties though, as you don't want the wires going out of control.
Good luck.
Good luck.
..... Trending Topics
My hands couldn't fit anywhere near the plugs until I dropped that thing.
thats how I had to do it... It really sucked. I had to do it in my parents dirt driveway. I was soooo mad, and my dad just laughed at me..
