Independent LE Trick flow numbers!
lift____int____exh
100___72.4___63.6
200__135.2__113.5
300__190.1__150.1
400__239.3__183.1
500__275.3__204.2
550__288.2__213.0
600__296.0__220.4
650__300.3__226.3
700__303.5__226.8
http://web.camaross.com/forums/showp...42&postcount=6
With a smaller valve you might have a higher velocity thru the venturi and a higher discharge coef (more flow thru a smaller hole) but can have worse perfromance since you don't have enough curtain area.
That line in my sig is there for a reason.
BTW
"Like a wise man told me before " you want to make a bad head look good, put it on a big motor".
To me that's a fast way to make a bad head look even worse.
Bret
Good work Lloyd.
Jonathan Bellas (3 sets of heads sent thru LE)...
Flowing at higher depressions may tell you more of what happens in the engine. If the port gets "noisy" at higher depressions, it probably indicates that the quality of the flow may not be good. Ports that stay quiet at high flowbench depressions seem to make more power.
Here's another link. Larry Meaux (maxracesoftware) has some interesting input on this topic.
http://speedtalk.com/forum/viewtopic.php?t=2161
This will tell you the potential of these heads.
A drag strip has to many variables, and flow benches and operators of these flow benches have too many variables.
Just my opinion.
Just my opinion.
As you said, the package counts, so just changing the head flow without complimenting it with intake, exhaust and valve timing might not give you the true potential of a set of heads.
If the cars get quicker and faster and the area under the dyno torque and hp curves keeps increasing incrementally, you are probably on the right track.
My $.02
