msd wires too big
Old Mar 21, 2006 | 10:40 PM
YngBird's Avatar
Default msd wires too big
what are the advantages for 8.5mm msd wires?i just ordered some an i know they wont fit the wire seperators.im trying to figure out if i should take em back.i got my msd coil too.i kept that its already on...what a difference
Old Mar 21, 2006 | 10:55 PM
imnotplutonium's Avatar
just overall less resistance and better insulation, i had a million problems with wires, burned too many sets, finally went with thunder's over the valve cover set. much much better, it uses taylor 8mm
Old Mar 21, 2006 | 10:57 PM
carzman5678's Avatar
The stock wire seperators are made to handle the 7mm stock. Youll figure out a way to route them.
Old Mar 22, 2006 | 01:08 AM
94'BLKBRD's Avatar
Old Mar 22, 2006 | 01:22 AM
94'BLKBRD's Avatar
Old Mar 22, 2006 | 04:14 AM
LT1 Guy's Avatar
Why don't you just buy wire separaters to fit your 8.5mm? I'm sure they wouldn't cost much.
Old Mar 22, 2006 | 07:18 AM
jclt12003's Avatar
i fit my MSD wires in the stock position. Yes it was a bitch and took time but they do fit with some patience and a lil TLC.
Jason
Old Mar 22, 2006 | 08:38 AM
savethelinoleum's Avatar
I used the MSD 8.5, the only problem I had was fitting them into the curved track underneath the alternator.. but they still worked fine.
https://ls1tech.com/forums/showthrea...61#post4463961
Page 6, I posted about my #2 wire being a pain because I tried to rush through it.. I have an LT1..
Old Mar 22, 2006 | 09:43 AM
sdm1234's Avatar
I just replaced my wires 2 days ago and my 8.5mm MSD wires DO fit in the seperators. It's about a 2-hour job just to route them, but it definitely IS do-able.
