Carb intake question
Old Mar 22, 2006 | 07:26 AM
LS1DUCE's Avatar
Default Carb intake question
I want to put a carburated intake on my lt1.
Does it have to be lt1 specific or will any small block intake work???
Thanks for the help
Old Mar 22, 2006 | 08:50 AM
IlEagle's Avatar
I'm running a standard GM Intake on my LT1 with a carb.
Old Mar 22, 2006 | 09:52 AM
lt1dave's Avatar
To run a standard intake you must either convert the heads to SBC bolt spacing, or the intake to LT1 bolt spacing. They also make lt1/lt4 specific carb intakes, but those are all dual plane setups
Old Mar 23, 2006 | 02:46 PM
LS1DUCE's Avatar
Default Intake
To The guys who run a super victor:
Do you mill off the water crossover and weld them up?(On a std sbc intake)
and the tap the heads for the std sbc intake???
What do i have to do??????
Old Mar 23, 2006 | 02:53 PM
Tony Shepherd's Avatar
PM sent
Old Mar 24, 2006 | 09:41 AM
SStrokerAce's Avatar
I weld up the bolt holes and take the water crossover off for weight and it's easier to work on then too.
It's easier to make the intake work than change the heads.
Send me a e-mail if you need any info on this.
Bret
