can i go to big?(injectors)
Old Mar 24, 2006 | 11:31 PM
BlazerINtheWork's Avatar
Default can i go to big?(injectors)
the stock ones were not going to cut it so while i was looking for some new injectors i came across a good deal on some #42's. will these be over kill? my setup is not extreme, just a cc305, 1.6 rr, headers w/ full exhaust, cai, and just about every other bolt on with a 6a box. if they are to much, is it something that can be fixed with a tune? i plan to have it dyno tuned. just worried that it will always be rich no matter what.
Old Mar 26, 2006 | 08:01 PM
T.t.t.
Old Mar 26, 2006 | 10:23 PM
Steve40th's Avatar
For a CC 305 stock 24# would be fine. If you dont believe me research this very subject throughout several forums.
That cam isnt that big.
I have friends running 10's with 24# and 30#'s on stroked engines. And there duty cycles are not saturated, but around 85-90%.
Old Mar 27, 2006 | 08:20 PM
dhdenney's Avatar
No probs out of 30#s for me. Duty cycle is always less than 90%. The 42#s aren't overkill necessarily but it makes a bigger hurdle in tuning.
Old Mar 28, 2006 | 11:44 AM
yeah i know its not a big cam. i will eventually go alot bigger, but i'm on a budget right now and i basicly got this cam for free. but thanks, what i needed to know. i was just worried about them being so big it would make it impossible to run right because of being so rich.
Old Mar 28, 2006 | 11:59 AM
infinitebird's Avatar
You should be fine. It won't run rich as long as it is tuned correctly.
Dyno tune is not really even needed, just need to set the injector constant properly.
Old Mar 28, 2006 | 10:11 PM
Dragframe's Avatar
yeah... it is a tuning thing. I am getting 42# SVO ford injectors because they are $250 for a set.... and i will have a stock LT1 with 6 psi of boost
Old Mar 28, 2006 | 11:50 PM
Lethal Z's Avatar
42lb injectors at 6 psi of boost in my opinion is overkill. The only way I would go 42's is if your planning on increasing boost. You can get them to run but the tune has gotta be dead on. I ran that size injector with 8lbs of boost and even with a good tune start up was a PITA. 36lb would have been perfect.
Old Mar 29, 2006 | 12:19 AM
Dragframe's Avatar
i haven't looked to see if there was a cheap alternative.. like 36# for $200-250...
