Nitrous Lie Or Truth
and... people will say this and that about nitrous... its hard to say... every car is different.
GENERALY speaking it is compltly safe as long as done correctly...but who is the one to say you dont have a piston wiht a weak ring land?? You never know...
But you could have 150,xxx on your car and i would say spray it. 100 shot on a healthy car regardless of miles will be fine (assuming everything is done right)
For Example I've always been told to find a high mileage engine and dyno it. Then run a 40 shot through it and dyno it after that. Ive always beentold the second time it will dyno a little higher because of the nitrous cleaning it out.
They also said this in car craft where they put all the nitrous they could to that junkyard 350 until it shot flames out the carb and melted a bunch of aluminum to the roof. Haha i wish i could do that.
As far as how hard it is on a motor, the extra power is there and put through parts far less often than boost and with the parasitic losses of a blower a 400rwhp blower setup is actually making a lot more at the flywheel than a 400rwhp nitrous or NA motor due to the power being consumed at the front of the frank to drive the blower.
If done properly you should be able to run nitrous on a motor and not have any problems. The problems arise when people run more nitrous than they are providing fuel for, or run enough to create more horsepower than the internal components can support.
if it was a catalyst there would be no need for any extra fuel. look up the definition of a catalyst if you don't understand.
it works by being able to get a lot more oxygen into the cylinder. more oxygen means you can add more fuel.
anyway, nitrous isn't BAD. it's all dependant on the setup. you see higher cylinder pressures (obvious from the very nice torque) and if your engine isn't able to handle that then it just isn't. so, it's all relative. if you have fine compression and your LT1 is operating like it is supposed to be then it can handle quite a bit of nitrous use.
i just read the first line of your post in my initial reply, but now that i've read it i'm pretty shocked. your understanding of nitrous and chemistry is way wya way way way off. do not ever give nitrous advice ever again until you do a lot of learning. it's ok because everyone has to learn at some point, but seriously, your misunderstanding of nitrous could cause problems if someone believes you.
i'm not going to rip it apart or anything, but a piston is sure not going to be a fuel source and your reasoning for everything is just wrong. there are plenty of nitrous write ups available so i dont' need to repeat it.
i don't need to think about it. i understand basic chemistry and that is also nothing like the explanation he gave. i simply stated that nitrous isn't going to attatch itself to whatever is avaialable and create combustion just because it's an oxidizer. you obviously need a certain amount of heat to burn whatever specific substance. there's a difference between melting and burning. sure you can melt a piston (aluminum melts around 1300 degrees F), but why don't you find me the flash point of it. OSHA doesn't even have that information available.
has it stopped you?
