more fuel system pics (installed)
Old Apr 3, 2006 | 12:35 AM
OutlawZ's Avatar
Default more fuel system pics (installed)
I've got a few more pics of the install that I completed tonight (the back half).... I had to buy longer bolts to get the straps to fit and I had to notch the trunk area (see pics) to get the gigantic 12AN 90 degree fitting to fit....
I know some haven't had to do that from the look of the pics but I realize every car is slightly different and my tank might not fit the exact way it does on all cars....
So far I am VERY impressed with the fit and finish of the Nasty Performance stuff. Nate has been very helpful throughout and although a tight fit you can see the R&D that goes into this tank. without the pump and the filters on the side you could probably toss this thing a quarter mile cuz it's THAT light.... So if you buy one of these tanks you probably need 10mmx1.5x100mm bolts.... Those are what I used.... you might get away with shorter ones depending on your straps. And I highly recommend pre bending the straps using a vise beforehand that way they lay down and angle where the tank angles (cause the stock tank is rounded....) enjoy!
Old Apr 3, 2006 | 01:22 AM
96silverram's Avatar
Man, that 12 AN line is massive !!! Looks good, now hurry up and finish the install so we can see the finished product
Old Apr 3, 2006 | 10:59 PM
emerica4601's Avatar
From: king of prussia, pa (home) and williamsport, pa (school)
impressive
Old Apr 4, 2006 | 06:22 PM
95zpro's Avatar
What size tank is that ? The system looks cool; I've been looking for something that holds more fuel than the stock 15.5 gal !
Old Apr 4, 2006 | 09:55 PM
The Nasty Performance tank probably holds a couple gallons less than 15 (12 to 13).
Old Apr 5, 2006 | 11:04 AM
OutlawZ's Avatar
Yeah I think it's listed at 14 but I believe it holds more like 12..... from what others have said.....
