"Tipical" times of...
Old Apr 5, 2006 | 08:21 PM
1fstpewter_maro's Avatar
Default "Tipical" times of...
I know the "tipical" ET times of an LS1 powered f-body with heads cam and stall are mid to high 11's depending on application, but what are the tipical ET times of an LT1 powered f-body with heads cam and stall?
Old Apr 5, 2006 | 08:51 PM
urbanhunter44's Avatar
If you replace the heads and cam on either engine, the sky is the limit. Both blocks have the same potential.
Old Apr 5, 2006 | 09:56 PM
96capricemgr's Avatar
People think a little too highly of the LS1 and not enough of the LT1. I would also say that 11s are definetely doable with a heads/cam LS1 but to say that is "typical" seems a stretch.
Old Apr 6, 2006 | 09:02 AM
omaha stylee's Avatar
are you talking strictly heads cam and stall? or with supporting bolt ons??? that will make a huge difference in each case.......... also i have seen bottom 10 sec ls1's with just a cam and supporting mods......... i have also seen some quick lt1's with just bolt ons going bottom 12's high 11's i believe
Old Apr 6, 2006 | 10:31 AM
blackedoutbird's Avatar
what he said
Old Apr 6, 2006 | 07:41 PM
Yea, I ment with other boltons like w/headers,throtles,cold air kit etc... yea I own a LS1 Z running 12.8s w/header gears lid cutout & on slicks, but I asked this ? because Im new to the LT1/LT4 motor. Also what et slips should my 89 iroc be making?, its a 350 (carburated) lt1 block w/fastburn heads lt4 hot cam 1.6 roller rockers pulleys headers cutout 3:42 gears and a >TCI stall <(not installed yet). w/ nitto drags. mid to low 12s? maybe...
