How to..create a manual fan switch!
Old May 5, 2006 | 08:35 AM
pr95blackbird's Avatar
can't you just make your own switch? i did it on my bird, sure it's a v6 but i'm almost certain the wiring is the same... if you want the 'walkthrough'/writeup how to do it yourself, let me know. it would cost you maybe 10bucks and 20mins of your time
Old May 5, 2006 | 10:08 AM
BlackBirdWs6Zzz's Avatar
You mid as well post it for the guys who need to make one anyways!
Old May 5, 2006 | 10:22 AM
fair enough... here you go guys!
http://shbox.com/1/fan_sw_diagram2.jpg
http://www.freewebtown.com/Loochy88/ManualFanSwitch.htm
http://shbox.com/1/fan_switch_wires.jpg
Old May 5, 2006 | 12:01 PM
Honda Hunter's Avatar
Originally Posted by Dragframe
i personally think the switch thing is getto... i would just have the turn on time changed...
and your buddy who jumped the relays could make you a switch if you wanted
I think the word "ghetto" is used way to frequently to describe what it shouldnt but I do get your point and I do agree.
Old May 5, 2006 | 12:11 PM
Just a thought but I think having a switch in the end may be well worth it. I remember when my temp switch went out and it was such a pain. Having a switch can be used not only when at the track but for emergency purpuses like a shot relay on the way home or bad temp switch. Couple that with a electric waterpump that turns on with the acc at the track...
Old May 5, 2006 | 12:27 PM
Oh, forgot to mention also that the Casper version seems to be better than the slp version and cheaper to boot. Caspers is a awesome business.
Old May 7, 2006 | 04:40 PM
Black LS1 T/A's Avatar
Moderator
I had this problem.
Trouble-shooting, I found the fans would work, the fuse was not blown, but my fans would not come on. The water temp would not cool down. It didn't make any sense.
I'll tell you why mine had stopped working. The jack that the 10 amp mini fuse is plugged into does not make good contact. Solder some thickening on the fuses's contact points, then insert it into the fuse box's jack. This will ensure a good connection.
It's a crazy defect, and at first it was intermittent.
Old May 8, 2006 | 06:37 AM
Smokinlt1's Avatar
I used the info on shoebox's site and did my own, less than $10 for the whole thing and it only took about 15-20 mins.
Old May 8, 2006 | 08:45 AM
glad this is working out for people!
Old May 26, 2006 | 08:52 PM
bubba24's Avatar
isnt there a sensor made by jet or hypertech a thermostatic switch that u can use to alter the fan turn on? Does these actually work? Its suppose to replace the sensor on the water pump.
