More "Project 8 sec LT1" pics not dialup friendly
Originally Posted by RedLT4Mike
Nice setup!
JM, what the hell are you doing in the LT1 forum??? lol![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Thanks guys.... Yeah I really hope it does well.... My engine builder has assured me it will have enough power to run in the 8's provided I have the ***** to stay in it if it gets up on the bumper.... I still have yet to get the rest of my rear suspension.... actually all I need is the double adj AFCO shocks and then it'll be done....
From those pics from what i can tell we might have different A-arms... your arms look a little thinner than mine. are yours BMR???? I don't have a good pic under the car on a lift but I will once it is running....
My FAST XFI system should be showing up soon and i've been busy wiring lately and setting up the numerous relays i need for the water pump, transmission cooler fan, fuel pump, and radiator fan.... But like I said i've been building this car for almost two years... maybe more.... I haven't cut ANY corners this time around and the old setup in this car went 10.40@131 with WAAAAY LESS motor and nitrous/suspension than this time around. Hell on stock k-member, front shocks, heavy front brakes, and a broken wolfe swaybar it was cutting 1.52 short times effortlessly.... it'll be quite another animal this time around....
Again thanks for the compliments.... I'll have some pics of the motor very soon...
Lookin good! Keep us updated!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I want to see the RWHP needle peg over 500RWHP... then i know i should be able to do it as well... How's the FAST wiring going????
Its going good. We are making it a plug and play. Utilizing one harness and only one harness. Will plug into the main harness under the dash so all of the factory gauges will work. Had to run the oil pressure sending unit, coolant temp, voltage....etc wires through the FAST harness loom to make it one harness. Taking your time makes it worth while in the end.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Mine is standalone with custom gauges so it'll pretty much plug and play as well..... i'm going to order the painless gauge harness so that all my gauges will have one power and one ground and just individual sending unit wires and taht's all...
[/quote]nice craftsmanship, see you have an eye for detail thats awesome[/quote]
thanks man..... yeah this time around i'm not cutting corners..... so i'll be relaxed when i bring it to the track instead of worrying about "that line I didn't properly secure" or "that pump i halfass wired".... I dealt with stuff like that before and swore i wouldn't this time.... thanks again...
