- Camaro and Firebird How to Install Engine Start/Stop Button<br>Step by step instructions for do-it-yourself repairs.
simplest way to rig up a push button start?
i found the right wire for the starter, and now when i connect it, my car cranks but will not turn over.
i'm getting 11.6 V from the battery, which should be enough to start it... should i use a thicker gauge wire?
does the fact that my ignition switch is probably broken matter? someone said that's the reason why my gauges don't work
