Question on where to mount sensor
Old Apr 22, 2006 | 10:06 AM
ThumpersZ28's Avatar
Question Question on where to mount sensor
Need to know where to mount the electric oil pressure sending unit for gauge
Motor is the 1994 camaro 350 LT-1
No Headers ....factory exhaust
details and or pic's will be helpful
Thanks in advance
Michael "Thumper"
Old Apr 22, 2006 | 11:54 AM
Loadre's Avatar
There will be an unused port on the block that is blocked off above the oil filter on the drivers side. You can either use that or you might have to 'T' it in with your stock oil pressure sending unit if it's mounted at the back of the intake (as opposed to the low mount version down by the oil filter)
Old Apr 22, 2006 | 12:30 PM
Default Thanks for the reply
Sending unit is installed....will need to wait to fire motor now to see it works
cranking the motor doesn't seem to get enough pressure to see if it reads
Michael "Thumper"
