No fire!!!
Old Apr 24, 2006 | 01:59 PM
porksoda's Avatar
Default No fire!!!
I have a 94 Trans Am with a new opti and waterpump as of 4000 miles ago. I have never washed the motor or driven the car in the rain either. Well its been running great since everything new but yesterday it decided to crap on itself again. For no apparent reason the car doesn't want to start now, I mean I did wash the car but that was just the outside of it. The car will crank and crank but it won;t ever fire up. What else can I check?
Old Apr 24, 2006 | 02:00 PM
Cchris1109's Avatar
starter
Old Apr 24, 2006 | 03:30 PM
Captainofiron's Avatar
You said its cranking over? but not turning on? It might be water in the Opti, or water got in the coil socket or in the coil module socket. you might want to test and see if your coil is firing, then move on to noid lights on each injector and see if you are getting fuel. After that its time to dig into the mystery world known as the PCM
Old Apr 24, 2006 | 03:38 PM
RoAdRaGe912's Avatar
you need to check fuel and spark. i'm sure the search function will find you something.
Old Apr 24, 2006 | 07:18 PM
transam5.7lt1's Avatar
Does it have spark at the end of spark plug wires? If it doesn't, check to see if it has spark from the coil to the opti... if it doesn't, done, you have a bad coil. That's what happened to me a little bit more than a month...
Old Apr 24, 2006 | 10:10 PM
96silverz28's Avatar
Default Firing blues???
Send me a pm and I'll walk you through some steps you cantake to diagnois the problem. All you'll need it a ohm meter, and it sure bets hanging parts on your car with on success.
Old Apr 25, 2006 | 10:37 AM
porksoda's Avatar
Sorry but I don't have an ohm meter.
Alright I checked the plug wires and their not getting any spark. How do I go about checking the coil? Pull the wire off the opti and do what?
Old Apr 25, 2006 | 02:22 PM
infinitebird's Avatar
You can get one for 10-20 dollars.
Old Apr 27, 2006 | 06:39 PM
porksoda's Avatar
Ok so far I've checked the wires by pulling a wire off a plug and sticking a screwdriver inside it while someone cranked the car to see if it sparked. I didn't get any spark there. I then pulled the coil wire off the opti and touched it with the screwdriver and held it close to the block as someone cranked it again. Still no spark. Am I doing this right or is the coil my problem?
Old Apr 27, 2006 | 09:39 PM
Default Troubleshooting Firing blues!!!
Give this link a try, it's a site provided by autozone that will allow you to troubleshoot automotive issues. If you don't have a ohm meter or do not have the knowledge on how to use one I'd recommend buying one. It would be smart to buy one rather than 1) paying someone to fix the car and 2) hanging parts on your car until you eventually find the problem. You can get a fairly inexpensize ohm meter from your local parts store or even wal-mart for as cheap as $20.
http://www.autozone.com/servlet/UiBr...3d801ce376.jsp
