Valvespring question
Old Apr 24, 2006 | 07:19 PM
6 spd LT1's Avatar
Default Valvespring question
does anyone know the max lift for the valvesprings that come with the LT4 hotcam kit? i know that the rockers that come with kit are rated at a max lift of .575". are the springs the same?
thanks, anthony
Old Apr 24, 2006 | 07:24 PM
DeltaT's Avatar
.540" max lift.
Jim
Old Apr 24, 2006 | 07:47 PM
Red97Z's Avatar
not to hijack your thread, but if they're good up to .540 lift, then that means my lt4 heads with the lt4 kit springs should hold up to a cc306 and a 847? i already have 1.6rr's
Old Apr 24, 2006 | 08:30 PM
96capricemgr's Avatar
There is a lot more to what a spring can handle than what lift it is safe too before bind.
The LT4 springs are marginal for the HOT cams .525 lift and mild lobes running it on a smaller cam with more aggressive lobes would be a lesson in what valve float feels/sounds like much less trying to put them on a bigger cam.
Old Apr 24, 2006 | 09:56 PM
DeltaT's Avatar
I agree but .540" is the safest lift in the approximate HOT cam style cam before getting too close to coil bind.
I checked this out a long time ago.
Jim
Old Apr 25, 2006 | 12:49 PM
ToxicTA's Avatar
Any suggestions for valve springs for a 95 LT1 383 with a Lingenfelter Mechanical Roller with Crane Gold Race Rockers 1.6 total valve lift .596
