ATI Procharger PB600 kit
it will feed up to 700 crank hp
dont know what it will cost to rebuild
i regret selling my p600b
go with a cam that has more duration on the exhaust 10-12 degrees
The By-pass that came in my kit stuck and then the P600B head unit exploded through my then new engine. I still have the Head unit as a reminder
You should not have any problems if you run low boost. I was pushing 14Psi per ATI directions and help at the time. the D1 was not out then
Jim
or are u still using the 12:1 fmu?supplied with the lt1 kit
Jim
Depends on where you put the MAF
So we will call it a "By-pass" Buy a good BOV and just route the out let back into the blower
BY-PASS LOL!
What's the combustion chamber on your heads?
