What do you idel at?
Old May 2, 2006 | 03:35 PM
CodyB4C's Avatar
Default What do you idel at?
mine idles at 1000 i think thats a little high though.
is it?
Old May 2, 2006 | 05:15 PM
94greencamaro's Avatar
My car idled around 600-700
Old May 2, 2006 | 05:18 PM
Honda Hunter's Avatar
970rpm's.
Old May 2, 2006 | 05:36 PM
blkchevyz's Avatar
thats a little high.
i think the computer shoots for 850 for a manual.
i see you have a throttle body, might try closing the blades alittle with the set screw and see if it goes down.
this is much easier to do if you have a scanner so you can see what the iac motor is doing..
or tach could easily be off by that much.
Old May 2, 2006 | 05:39 PM
zigroid's Avatar
1200 or so when its cold, 1000 when its warm. anything below 1000 and the engine sounds like its gonna die.
Old May 2, 2006 | 05:40 PM
J2Pharren1's Avatar
Yea, the LE3 will do that
Old May 2, 2006 | 05:43 PM
Not only that but it for me Ill run rich at idle if set to low. I have something like a LE3.3 I guess.
Old May 2, 2006 | 07:00 PM
outdooricon's Avatar
she likes to idle at 2000 for a little bit and then drops down to 1000... I'm guessing that's cause of my performace tune from pcm4less?
Old May 2, 2006 | 07:10 PM
93BlackZ's Avatar
~850, just the bolt ons
Old May 2, 2006 | 07:14 PM
funny you should mention that. mine does the same thing sometimes. hmmm
Old May 2, 2006 | 07:36 PM
What mods have you done?
Old May 2, 2006 | 07:39 PM
383 with every bolt on, decent sized cam and 9.0 dcr. I also think my idle screw on the t/b has something to do with it.
Old May 2, 2006 | 07:43 PM
My1st Truck's Avatar
Bone stock A4 right around 800
Old May 2, 2006 | 07:51 PM
thecamarokid's Avatar
My tach says 1000rpms but when I hooked it up to the computer its idles right around 850ish. Its a 93' M6.
Old May 2, 2006 | 07:54 PM
That's a good point. I didnt find out my stock rpm gauge was off until I got my scanmaster.
Old May 2, 2006 | 08:00 PM
luckyou03's Avatar
hotcam, 650-700
Old May 2, 2006 | 08:33 PM
LukePhillips's Avatar
In Need of Cup Holders!
900ish I think. Stock.
Old May 3, 2006 | 08:05 PM
P97LT106's Avatar
Mine idles at 1000, but i hooked an aftermarket tach up to it straight to the tach lead on the computer and that tach says it idles at 800. i have heard quite a bit that stock tach's are fast by 200 or so. But i have also heard that GM made the idle different in alot of cars due to the gearing of the car. My friend has a police package with the 2.73 rear end and his idles at 500 on the stock tach.
Old May 3, 2006 | 08:07 PM
hurley711's Avatar
LS1 edit set to 900
Old May 4, 2006 | 12:09 AM
omaha stylee's Avatar
600ish when all warmed up
By Brett Foote | 2026-06-04 05:00:17
