From bone stock to drag racing!!!!!
Last edited by antonio; May 2, 2006 at 04:08 PM. Reason: Anybody have any recommendations to turn a stock LT-1 into a bad drag racing engine!!!!!!
Well if you want to go all out and drag race, it depends on what engine you want to run. you could stroke out and turbo your LT1, that is what I would do first. Or you could strip out your interior and put a roll cage and subframe connectors. either of those two is what I would do first
9" rear end ~$2500
TH400 with stall and trans brake ~$1500
Suspension ~$1800 if you go all out, probobly more
Wheels and Slicks ~$1200
and you're still making stock power at this point. You could do a big Cam with some ported Heads and maybe see 400whp assuming you have proper supporting mods, after tunning you're probobly looking at $4,000 when its all said and done (That includese the supporting mods I was talking about) After that you can either stroke out the bottom end to a 408 (which will require a new head/cam combo to make more power, so another $2,000 for that, and probobly $3,500 for the bottom end) or go turbo, which could easily hit $4,000.
People may tell you it will be cheaper, but it won't be, especialy if you have to pay some one to do the work.
9" rear end ~$2500
get rid of the weak links first, then get the suspension worked out... then start working on getting more power.
www.eportworks.com for the heads/cam
Those are the necessities of a bad *** track car, and while you do all of that, you can spend the time also thinking about the motor, thats what I would do atleast. http://www.ls1speed.com/intmd8.cfm
