hesitation?
any idea what this is or what could cause it? I have to add that my car is operating at higher than usual temps (it used to run normally between 185-200, but now with real hot weather its somewhere in the range of 210-235)
any ideas? i cant get the codes since i dont have a scanner and no where close by does it for cheap
bring the car to me or Ill come to you and read your codes for you easilly. If youre OBD1 with a 94 connection then it's all good. OBD2 or OBD2 connection I have no cable or software for.
Tag has all what is needed for OBDII.
