How to turn over engine?
Can I just put the crankshaft hub bolt back in without the hub and then turn the engine over to get it back at TDC on cylinder 1 and then just throw a strap wrench over the end of the crank shaft (to hold it) and pull the bolt back out???
tightened it till the socket was snug against the crank then turned it. basicly used the socket instead of a bunch of washers.
just make sure you have the bolt threaded in enough so you dont pull the threads out.
