any have any gains #'s from cc 503
I ran the CC306 on stock heads and 2200 stall... Limitation is the heads. The CC306 makes a ton of power but on stock heads it struggles to make 350rwhp. Once you open the heads up you can make insane amounts of power.
As said about I had some surge around 2K.. but even with the Auto I didn't notice it too bad.
As for the 503 Ive never worked with it... so I can't add anything useful.
the 503 is a good cam for stock heads, but you're not going to make 400rwhp with it. I would just go with that for now and then switch it to a bigger one (like the LE2) if you're going with LE heads later.
Any more ?
Originally Posted by BlackBirdWs6Zzz
I didn't think I was going to make 400hp with just a cam. I was thinking a cam to get around 340 and then add heads later to get somewhere near 400
If you want 400rwhp all motor it's going to take a bigger cam than that.
Originally Posted by ls1charged
just get the LE2 heads and cam package, you will get 400hp from that.
i just got a CC503 put in my car and i really like it. i havnt been able to test it fully yet because of a tranny problem but it seems really responsive even in 3rd. i would definately recomend getting a stall with the cam as well. i hope to hit 450 hp on spray with it. here is a list of my mods.
Comp Cam 224/230 .503/.510
Comp Lifters
Comp 915 Beehive Springs
Comp Locks
Comp Retainers
Comp Pro Maginum 1.6 Rockers
Comp 7/16 Rocker Arm Studs
Lunati Timing Set
GMPP Guide Plates
Hooker Super Comp Long Tube Headers
Summit Universal 3'' X Pipe
Flow Master Delta Flow Mufflers
Hypertech 160* Thermostat
K&N FIPK2 Cold Air Kit
March Underdrive & Alternator Pullies
Black Z06 Motorsport Wheels
17x9.5 fronts w/Kumho Ecsta 275/35/17
18x10.5 backs w/Goodyear Eagle F1 295/35/18
Mickey Thompson ET Streets 26x11.50
Comp Lifters
Comp Locks
Comp Retainers
Lunati Timing Set
GMPP Guide Plates
#33
Comp Lifters
Comp Locks
Comp Retainers
Lunati Timing Set
GMPP Guide Plates
Comp Lifters
Comp Locks
Comp Retainers
Lunati Timing Set
GMPP Guide Plates
#34
i dont have any numbers at the moment because when i picked my car up from the cam swap it was mysteriously missing 2nd and 4th gear. the guy that did my cam swap claims he never drove it but hes full of ****. on a brighter note 1st and 3rd are very strong. and to anyone interested in getting a cam for the sound i would also recommend this cam, i cant tell u how many people have just stared at my car at stop lights over the last 3 days because of how hard the cam hits.
#36
OH ok I see. Well did you get plenty of power after that surge?
What's the cause of the surge? Is it not flowing enough or.....Just wondering (for my knowledge bank)
So yeah..PLENTY of power after the surging point.
#37
Well I talked to loyd and this is what he said.
Best bang for the buck is the $800 LE1 heads. They will work great with that cam and will make anywhere from 350 to 390 RWHP (depending on the rest of the set up).
You will also need some bigger inj, some headers/exhaust and good tuning to get to the 350-360 RWHP range. Better headers, ported intake, bigger TB, etc, etc are all needed to get you in the 380-390 RWHP range.
So basically my plan is cc503 cam first until I have money for the heads. then it's time to get nasty. hehe hehe. thanks for your help guys!!
#38
#39
I will be doing something a little different this summer, but it sounds like we are in the same boat, new motor sitting in a garage and you want somewhere around 340rwhp.
i plan on doing a cc305 (220/230) with scorpian 1.7 RR's (.578/.578) as soon as I get back from Europe. I'm about two months away from it happening but I thought I would throw it at you.
#40
is it obnoxiouse loud, or a good sounding loud. if loud at all?
