catch can
Old May 18, 2006 | 04:07 PM
imnotplutonium's Avatar
Originally Posted by horsekilla 95TA
Here are the pics of my setup. I know it is dirty LMAO....
ok i have exactly the set up you do, but I can not find the lines on the driver side. I put the breather filter on the passenger side and replaced the original hose, it was crumbling in my hand so I figured that could only help it if i got a brand spanking new hose. what performance loss would I get if the hose wasnt sealed right?
and again where are the hook-ups for the can. I looked all over and didnt find anything on the drivers side. unless you are just doing it to the pass. side.
Old May 18, 2006 | 04:09 PM
Originally Posted by thesoundandthefury
Something you might wanna consider, which is exactly the reason why I did this on mine, is to do a battery relocation. The previous owner of my car didn't understand alot about battery maintenance judging by how the car looked when I first bought it, (didn't understand alot of anything judging by the # of fuckups I've fixed since I've had it), and subsequently there was battery acid/corrosion all over the inner fenderwell and on top of the battery tray. Paint was eaten away all around that area and it was rusted. Looked like ****. So I relocated my battery to the trunk and took out the stock battery tray/overflow tank in favor of swapping in a stainless overflow tank. The cubbyhole in the framerail that the stock overflow tank resided in was almost the perfect size. Thing is though, with the battery out of the way there is enough space freed up that you could mount two catch cans in that spot if you wanted to: one for the radiator, (if you wanted it), and one for the oil.
Probably a more complicated solution than you wanted to hear but what about these cars isn't complicated?
yea i was thinking of doing it too. but how hard is it to do? just run a line to the back and have the battery set up there? If I do that I should prolly re-run the lines to my amps as well huh? so the power doesnt go to the front just to have to come all the way back again.
Old May 18, 2006 | 04:11 PM
blkchevyz's Avatar
i thought ls1 are the ones that burn oil... we just leak it
Old May 18, 2006 | 04:15 PM
horsekilla 95TA's Avatar
The hose coming from the right side of my catch can is going to my PCV valve in the side of the intake manifold and the hose coming from the left hand side is going to a nipple on the intake manifold located under the throttle body. This line is ran to the exact locations that the factory PCV line went to. I had more pics but didn't have time to get them loaded up the passenger side of mine is ran exactly like the factory setup but it just has a duetsh filter in the valve cover connected to the factory vaccume line going into the passenger side of the Throttle body.
My setup is ran exactly like the factory PCV setup but it just has the catch can on the drivers side and a filter on the passenger side. It works very well for me. I can post more pics on Saturday night when I get back to my home computer.
Old May 18, 2006 | 04:17 PM
I thought that too until i tried the catch can...
Old May 18, 2006 | 04:35 PM
ok so i'm doing it right I am just having a hard time finding the pcv system on the driver's side
Old May 19, 2006 | 02:25 PM
http://shbox.com/1/pcv.jpg
That is the PCV valve and it is about half way down the drivers side of the intake manifold.
Old May 19, 2006 | 05:32 PM
Honda Hunter's Avatar
You get more oil in the tract from the passenger side
Old May 20, 2006 | 09:49 PM
Maybe later I will try one on that side but the drivers side seems to have alot in it also. I have stopped somewhere between a 1/2 - 3/4 of a quart on the drivers side so far in about 10,000 miles with my setup. How is yours setup on the passenger side?
Old May 25, 2006 | 05:26 PM
bone324's Avatar
Could you elaborate? You have a filter on the passenger side? Is that a breather? I was going to trash my breather and just put a catch can in line between the right side valve cover and the throttle body. Would a catch can on both sides be better?
Old May 26, 2006 | 12:26 AM
TwoFast4Lv's Avatar
The oil I am sucking in is directly through the PCV system. almost none from the pass Valve cover..
look here.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8066562179
they come in a strange CF look a like pattern but they work well
Old May 26, 2006 | 10:22 AM
  #32
NotACop97Z's Avatar
look here.
Wow That think is nice!!!
Old May 26, 2006 | 10:11 PM
  #33
I am running a BF412 Deutsh filter inline on the passenger side valve cover you can see it in the pic I have attached. If you can't tell by that pic let me know I will host it somewhere else where I can get a larger pic.
The driver's side is ran like in the earlier pic that I posted in this thread with a catch can inline. If you need that pic again let me know.
Old May 27, 2006 | 02:24 AM
  #34
bone324's Avatar
Yeah, can't see it, but this is a good pic and explanation:
http://collop.cz28.com/custom2.html
If I run a setup like yours should I keep the breather or plug it? I'm getting oil dripping out onto my plug wires, valve cover, etc. I was under the impression that I should vent the crankcase with the additional pressure added by the blower, is that right?
