Another LT1 Rookie
Old May 20, 2006 | 11:21 AM
kevin-557's Avatar
Question Another LT1 Rookie
Hey all, I need some pointers from you seasoned veterens. I'd like to start building another engine for my '94 T/A. My thoughts were a 383 with the LT4 top end, and AFR LT4 heads. Can i start off with any 350 block, or are there certain years i need to look for so everything will bolt on from my exsisting LT1??? Does this combo sound feasable?? Also, when i get the crank, are they single piece rear main or not?? Any imput is welcome
Old May 20, 2006 | 11:32 AM
LT14LIFE JT's Avatar
On the block, NO. Only LT1 blocks are feasable...On the rear main seal, 1 piece. If you're going 383, look for a 92-96 corvette block..It's 4 bolt main, where f-body had only 2 bolt. Hope this helps.
Old May 20, 2006 | 12:24 PM
97blkz's Avatar
Yeup! I think the SS motors were also 4 bolt mains too?
Old May 20, 2006 | 12:59 PM
96capricemgr's Avatar
I would say you are going about it wrong and the info given sofar is near worthless.
If you bother to look into what places are doing with ported stock heads you SHOULD rethink your asumption of needing different castings. If you do the LT4s get them ported but you don't need to buy them atall especially with thwe intake availablility provlems. AFRs SUCK unless you get big ones and are building an aggressive motor the smaller street targetted stuff will not perform as well as a competently ported GM LT1 casting.
On the 4 bolt by the time 4 bolt mains are genuinely an upgrade you should be considering you should be looking at an aftermarket conversion, BUT the stock 2 bolt is a hell of a lot tougher than the inexperianced want to give it credit for.
Old May 20, 2006 | 02:40 PM
Honda Hunter's Avatar
Since when?
Old May 20, 2006 | 02:43 PM
The f-bodies that got LT4s would have gotten 4 bolt mains, not real likely to find one of those. Also warranty replacement motors were 4 bolt, but again if you need 4 bolt strength go aftermarket splayed. For most of us though untouched 2 bolt or studded 2 bolt will hoild just fine.
Old May 20, 2006 | 03:01 PM
97blkz's Avatar
thank you sir!
Old May 20, 2006 | 04:57 PM
slowmofo's Avatar
beat me too it....
very rare cars
Old May 20, 2006 | 09:10 PM
kevin-557's Avatar
Okay, this does help alot, i'll find an LT1 block to start with. The reason for starting with another block is to keep my down time at a minimum. It would be better for me to have the other motor ready to drop in. One piece rear main it is and it sounds like from the other post, the LT1 heads ported out will work fine. Thanks for the info so far. I'll be asking more rookie questions shortly.
Old May 20, 2006 | 09:21 PM
At least you know you are a rookie that helps you a lot by allowing you to learn.
