LT1 block
Old May 20, 2006 | 11:38 AM
NOTAV6's Avatar
Default LT1 block
hey i found this for sale but he says this what exactly does this mean its a 4bolt main LT1 out of a 92 vette but what does this mean "4-Bolt 350 Block (only the center 3 caps are 4-bolt)"
Old May 20, 2006 | 04:16 PM
aboatguy's Avatar
From 1992-1996 Corvettes used LT1/LT4 engines with four bolt mains. The center main bearing caps are secured by two bolts per side (4 bolts per cap) vice the one bolt per side (2 bolts per cap) on most LT. This is supposed to be stronger set up than normal two bolt engines; however, I have seen two bolt main engines survive all kinds of abuse.
Mike
Old May 20, 2006 | 05:58 PM
OutlawZ's Avatar
yeah 4 bolt main motors have only the three center caps held on with 4 bolts. The front cap is still 2 bolts, and the back cap which holds your oil pump mount and thrust bearing is 2 bolts....
4 bolt blocks are stronger.... more sturdy due to better holding power on the crank...
Old May 21, 2006 | 12:05 AM
NOTAV6's Avatar
ok thanks for the input guys i knew the 4 bolt is stronger so i have been looking for one to build (i just didnt really know exacty what it meant never looked into it real deep) for boost which i could just get mine splayed to it but i would rather start out with a 4-bolt block.... gonna have to look at picking it up cause they only want like 750$ for it last time i checked
Old May 21, 2006 | 11:28 AM
aboatguy's Avatar
Splayed is probably the better choice. Mike
Old May 21, 2006 | 01:13 PM
the_merv's Avatar
Veteran: Air Force
Is it $750 for the Block, or a complete engine?
Old May 21, 2006 | 01:14 PM
NOTAV6's Avatar
assembled short block but ill be taking it apart anyway
Old May 21, 2006 | 02:40 PM
396D1SS's Avatar
750 for a stock shortblock? overpriced!
