Guys running the Milodon stroker notched oil pan (30909)
Just spoke to my friend and my stroker is pretty much done, just needs to be put into my car and hs said that should be done today.Only problem he says is that the if you try and put the dipstick back in, it will not go in. I was wondering if you guys running this oil pan have had a problem like this as well? It is just the stock dipstick. Can it be trimmed down a bit to fit? I just feel a little uncomfortable about it, as there is now no low oil sensor and dipstick if I cannot get this to work.
