single plane intake
Old May 28, 2006 | 02:09 PM
96 LT-1's Avatar
Bad Seller Warning!
Default single plane intake
what do I have to do to convert to a carb? i have a 1996 Formula and what kind of advantage will i get from this swap?
Old May 28, 2006 | 02:16 PM
Smokey TA's Avatar
i think it is a wasted of money but if u want to do it u can. the differents are the peak HP will be a little higher but loss thorttle responds.
Old May 28, 2006 | 02:45 PM
96 LT-1's Avatar
Bad Seller Warning!
is there any intake i can do???? or is it just best to port and polish a stocker???
Old May 28, 2006 | 02:51 PM
OutlawZ's Avatar
You specifically want a carb or just a carb "style" intake and still run Fuel Injection?????
There's a few intakes that would fit but I believe they would all need to be modified to fit an LT1/LT4 style intake bolt pattern.... Might wanna call Port Pros (sponsor on this site) for more info. I'm having them do my Edelbrock Victor "E" manifold but i'm keeping fuel injection and just running a much higher flow single plane manifold for the upper RPM power.....
Old May 28, 2006 | 07:12 PM
SStrokerAce's Avatar
Another one from the "Not to get on your case but" department....
Have you ever even looked at a dyno chart of this? Or even drove around a motor with one on it? I'm guessing by the answers to this thread, that's a big no.
Bret
Old May 28, 2006 | 07:23 PM
96 LT-1's Avatar
Bad Seller Warning!
I'm just looking for a good intake... what would be the best bet for me ? im going with H/C and lots of spray most likely....
Old May 28, 2006 | 07:29 PM
OutlawZ's Avatar
still haven't said whether or not it's going to remain fuel injected or if you're going with a carbuerator.....
If you're going to keep your fuel injection and want to run a single plane intake I'd say have either Port Pros or Bret Bauer do up a Victor "E" manifold for you..... has fuel injector bungs cast into the manifold and you can buy fuel rails that fit it... it's basically a victor jr setup for EFI.... It would need to be ported and have the stock holes welded up and new holes drilled for the LT1/4 style bolt pattern on the heads....
Old May 28, 2006 | 09:48 PM
96 LT-1's Avatar
Bad Seller Warning!
i dont know what i want to go with... everyone says fuel injectyion is better
Old May 29, 2006 | 11:52 AM
#1. Remember that a N2O motor is still a NA motor just with more O2 injected into the motor.
#2. Victor E intakes I don't do or recomend. They don't have the cross sectional area that most setups need without crazy porting, they weight about twice what a converted single plane will weight and they definately need a carb spacer to get the right transition into the inner runners.
#3. I wouldn't do this unless I had a bottom end built as well.
Bret
Old May 29, 2006 | 11:56 AM
Tony Shepherd's Avatar
I am running the Victor E with no problems. The spacer I use is the nitrous plate!! LOL.
Old May 29, 2006 | 03:12 PM
Formula_LT1's Avatar
Anyone have good luck out of the GM performance parts carb intake for LT1's?
I'm building a carbed LT1 for another car I have, but didn't know if it was worth spending $250 on over a single plane intake and having it machined to fit?
Old May 29, 2006 | 03:23 PM
aggiez28's Avatar
bret does a really nice job on his conversions btw.
brook
