MSD cap and rotor kit..DEAD!
Hope this was a freak issue, 1200 miles isn't gonna cut it
I've recently discovered that I have an MSD 6 box on a shelf from years ago (was for the Monte) and with the appropriate MSD cable, it’ll work with the stock system.
If I upgrade to the MSD box, will I blow holes through my rotor? Holes or not, will there be a performance gain?
I must have missed that? You got a link? Not sure what they will do. I just dug out the box and it has a 12/06/05 date on it as does the other kit we bought(we got two at the same time).
For all those who had had good luck with there stock Opti as has been said ten billion time...we are happy for you
My car has 58255 miles on it and four opti's
Actually the optic section is still good on all the ones I took off my car. but not a singal cap and rotor made it out alive.BTW it is not like this is a singal event for just my car. Here at Speed Secrets we still replace them for customers on a regular basis
I know I know it is just us here in washington state
I hope all of you have continued good luck!
then again this thread was not for you to gloat in
I guess I'm there too..on how many opti-craps have I been through....
My original (NO MSD6 at the time) lasted 50k miles....Of course, I never tried to rev it past the 5800 rpm limiter back then.....Now when they go, it usually starts above 6k then sputters..then moves down the rpm scale till your screwed just trying to drive it......."MSD's" due play havic with the ozone and carbon tracking on them....
I will be the first to say I was pretty damn pissed when the failure happened. MSD has gone out of there way to make sure they have taken care of this and ANY future problems.
I have used many MSD products in the past and bought many new MSD parts (FULL DIS-4 Plus system) to replace what I was removing this time.
Besides being broke down and being pushed on a trailer by the people at the FORD dealer and missing three races now things went very well and MSD did every thing they could to make the event painless as possible.
We are going to install the Same system I took off the car on the second Shop car just to make sure
no problems anymore pulling it to 7k a few times
