GForce is kicking butt on the PEPPE project
Old Jun 17, 2006 | 05:40 PM
  #41
OutlawZ's Avatar
hey man where the heck is your alternator????
I was looking at the pics and it looks like you used a dummy pulley where the alt was right???? I guess you kept your power steering so you still needed to use the bracket???? But where's the alternator? Low mount madman setup???
Old Jun 17, 2006 | 06:19 PM
  #42
-PEPE-'s Avatar
It's a SpeedSpecialty alt relocation brkt which relocates it where the old air/smog pumps we all remove were located (drivers side), this brkt allows you to keep your PS & AC. I have a new compressor and all my lines polished, the AC delete pulley was free & just wanted to make a pass @the track without it for the hell of it.
Old Jun 18, 2006 | 12:27 PM
  #43
OutlawZ's Avatar
cool.... i ditched the power steering (madman manual rack), and i'm going to run the madman low mount alt kit so I can ditch the giant bracket on the pass side.... I Might have to figure out how in the belt routing i can run a vacuum pump tho..... So I'll only have a belt going to the alt, vacuum pump, and the balancer....
Old Jun 19, 2006 | 09:54 AM
  #44
-PEPE-'s Avatar
Been looking at some vacuum pump options myself, you'll have to shoot me some info on your setup, I have very little to go by at this time, other than a local LS1 (cam only) picked up around 13rwhp with a custom vacuum pump setup they did.
Old Jun 19, 2006 | 03:55 PM
  #45
O Holy P's Avatar
I'm using the Cobra R elec. crankcase evac. pump. I haven't been to the dyno with it to see if it does any good or not. But when I do I'll turn it off for one run and see what it does. Here's a few pics...
Vac 1
Vac 2
P
Old Jun 19, 2006 | 04:50 PM
  #46
Tony Shepherd's Avatar
P.......that pump only pulls about 5 inches of vaccum. Not really enough to do anything. I used that pump for a little while but it really did not help much. I now went to a Moroso 3 vane pump.
Old Jun 20, 2006 | 10:07 AM
  #47
-PEPE-'s Avatar
Sure thats not a Jegs or Summit item, where'd ya get it?
Old Jun 20, 2006 | 11:37 AM
  #48
I got the Cobra R pump from a Ford dealer. Got the Moroso pump from Summit.
Old Jun 20, 2006 | 11:58 AM
  #49
-PEPE-'s Avatar
Thanks for the tips on the vacuum info you two. Ya know my buddy did something similar on his 93 Formula 383, but he used the vacuum eduction setup for longtubes, personally I don't care for that setup in that it's not much vacuum compared to a pump setup. Another thing I'd like to do is set this up with all AN fittings on custom welded tall vavle covers along with an oil catch can.
Old Jun 20, 2006 | 12:18 PM
  #50
I recommend you stay away from the electric pumps
Old Jun 20, 2006 | 12:32 PM
  #51
OutlawZ's Avatar
I recommend tony shepherd PM's me some pics of his crab distributor and his crank trigger
I'm getting ready to buy parts soon for this and need to see what it'll require...
And yes definitely stay away from electric vacuum pumps...
Old Jun 20, 2006 | 12:38 PM
  #52
-PEPE-'s Avatar
recommendation taken, so what do you recommend then if not electric, the crank vacuum options are new to me, think I understand the basic principle of it now but not clear on all the best options for obtaining vacuum for this.
Old Jun 20, 2006 | 12:39 PM
  #53
Old Jun 20, 2006 | 02:29 PM
  #54
TwoFast4Lv's Avatar
HEY I have one of those distributors laying here in a box
Old Jun 20, 2006 | 09:57 PM
  #55
OutlawZ's Avatar
shweet... can you pm me some part #'s????
Tony would be the man about the vacuum pump. I think i'm going to run an Aerospace components 3 vane but i'm letting my engine builder deal with that issue...
