Help out PCV or brake booster lt1
May be stupid but i need some help im putting some seafoam in and im not to sure exactly where the PCV line is or the brake booster line is located. Can someone tell me or show me a picture i have a 93 lt1 trans am to be more helpful thanks
What does that do when you connect that one to the PCV Valve, isn't that the EGR Vacumn connection. Does it just keep them 2 holes plugged basically. Isn't the one in the front of the Intake where the Vent for the Crank Case is, and that runs to the PCV so it burns the fumes? I wonder if you can put a little filter on that, and do it that way...
Putting it into the port labeled "brake booster" would be his best bet.
