Carbureting the LT1
Yep, I am going to do it. Going to 406 cu in. and carb it, grout the block, and slap a BIG shot to it. Not going to be a street car so no concerns on gas and all that BS. I know Frans96ss has done a motor for this but the things I know I will need is. A carb,intake,distributor, and what else ? I am really looking for some of you guys that have done this or if some could point me to some added info would be great. If anyone has pics of there setup that also would be sweet to see. Thanks gang, Chris
We have done a few Carbed LT1's but they werent in 4th gens. If i remember correctly we just welded the hole shut on the front cover, bought an intake/carb and distrubutor and hooked it all up. There may be a tad more involved on a 4th gen but I am sure nothing major. You probably already know this but the GM conversion intake available isn't really all that good, so a Super Vic(or similar style) convertered to fit the LT1 would be a much better idea.
EDIT: Are you keeping the LT1 platform or going the old school SBC route with plans for a 406 i am guess that you are going SBC. Not really sure, either way hope the info helps.
there is nothing "weak" about the lt1. no more than any other 2 bolt 350. just take the block, half fill it with block hardener, and have the caps splayed to 4 bolt.
as for the carb thing....i REALLY like the idea of a carbed lt1. i've seen a couple of them make some very impressive numbers.
as for as ease of doing it, it's a little more invloved then your original post. if you use a standard sbc intake, there are a couple holes in the intake that have to be welded, there was an article in super chevy a while back that explained this saying any sbc intake can be used once these to water holes were welded shut.
i've seen the gmmp intake do well on one car, but it won't be a sufficient supply of air to a 406.
the only disadvantage of the carbed lt1 is timing....it's very hard to get the lt1 timed without the computer....i don't know why, but we've always had trouble with that.
