warm cockpit
Old Jun 28, 2006 | 10:33 PM
NOTAV6's Avatar
mine was the same way ..... usually if i just turned the cold warmth selector to the cold side the warm air would stop coming in .... even with the other selector set to the off selection
Old Jun 28, 2006 | 10:56 PM
oneBADDz's Avatar
Originally Posted by emj2006
its not about when controlling the heater or anything, you just feel heat around the shifter area/floor. This is when you feel heat when you have your A/C or heater system completely off.
Regardless of whether you have it turned on or off the fan is continuous. It will blow whatever temp you have the temp **** set to out the floor vents when the fan switch is turned off.
Old Jun 29, 2006 | 01:39 AM
the_merv's Avatar
Originally Posted by 4ced
pics or a little more detail plz
someone mentioned a link?
I don't have any means of getting you a pic, but it's a little black plastic tube that has a T connect, and one of the tubes goes in the fire wall, the other goes toward the AC Compressor, and the third goes toward the Engine. The T is located near the Computer.
