warm cockpit
Old Jun 20, 2006 | 10:59 AM
4ced's Avatar
Default warm cockpit
Is this the usual case with all camaros, becuase I dont remember the car doing this until recently (or maybe i just realized it since the weather has become so warm)
I know these engines heat up a lot but is it normal for a lot of this heat to get into the cockpit? it seems more obvious when i drive on a highway that the heat is forcing itself in the cockpit...
is this normal or is there something wrong with the car?
Old Jun 20, 2006 | 11:05 AM
the_merv's Avatar
Sounds like the lower vents are stuck open. Sometimes they do that.
Old Jun 20, 2006 | 02:16 PM
4ced's Avatar
whats the fix then
where are the vents located? any pics?
Old Jun 20, 2006 | 02:21 PM
dhdenney's Avatar
I've noticed my floor pans get very warm. After driving you can put your hands down on the carpet and you can feel how hot they are.
Old Jun 20, 2006 | 11:22 PM
4ced's Avatar
yeah... but i mean i feel warm air coming into the car, its from somewhere under the dash but not sure where exactly
Old Jun 21, 2006 | 12:49 AM
the_merv's Avatar
I never taken one on a Camaro apart, but the lower one on my Caddy is open all the time. It's not really that bad on that car, it feels nice when it gets cool out. I don't know how hot it is in the Camaro though.
Old Jun 21, 2006 | 05:23 AM
LT1BRN's Avatar
Dude, ur cokpit isnt warm, its freaking Hot.
take it to a pro, there must be somethign wrong.
Old Jun 21, 2006 | 06:08 AM
96 LT-1's Avatar
Bad Seller Warning!
i have the same problem also anyone have a fix for this???
Old Jun 24, 2006 | 01:49 PM
96 LT-1's Avatar
Bad Seller Warning!
noone has a fix?
Old Jun 24, 2006 | 03:29 PM
Red97Z's Avatar
I have also felt an occasional warm blast of air on my legs when driving my car, it came from underneath my steering column...
Old Jun 24, 2006 | 03:31 PM
urbanhunter44's Avatar
My vacuum thing next to the heater box was busted open and kept the vents open, check yours. Shoebox's site has a good article on it.
Old Jun 24, 2006 | 06:43 PM
Black1997T/A's Avatar
I noticed the same thing on My car. For me, the cause was from having the Temp. control switch in the warm position. After I moved it to the cool position I got cooler air coming in. Try it I bet thats whats going on.
Old Jun 25, 2006 | 05:10 AM
NOTAV6's Avatar
yeah i need to go get my A/C recharged, emptied it when i took the motor out so all i get is hot air lol really sucks being here in TX freakin hot right now and no A/C and i get the hot air on the legs cause mine does that to, did it before but it only if i didnt have the selector on the cold area if i had it on the warm area it would let the warm are in
Old Jun 25, 2006 | 07:27 AM
the_merv's Avatar
I have 2-55 AC in mine. 2 Windows down going 55mph...
Old Jun 25, 2006 | 08:26 AM
96 LT-1's Avatar
Bad Seller Warning!
someone help me with this there has to be some way to fix this.
Old Jun 25, 2006 | 10:01 AM
the_merv's Avatar
Someone mentioned it earlier,the Vacuum is not working properly to that vent. It could be broken, or have popped off. I found one of the Vacuum Lines located near the PCM, it is plastic, and touchy, so be careful how you handle it.
Old Jun 25, 2006 | 10:26 AM
4ced's Avatar
pics or a little more detail plz
someone mentioned a link?
Old Jun 25, 2006 | 10:30 AM
96 LT-1's Avatar
Bad Seller Warning!
yah i need something more... lol hot air comes out on both passenger and drivers feet.
Old Jun 28, 2006 | 09:42 PM
emj2006's Avatar
lol I have the EXACT same thing happen to me!
Old Jun 28, 2006 | 09:46 PM
emj2006's Avatar
its not about when controlling the heater or anything, you just feel heat around the shifter area/floor. This is when you feel heat when you have your A/C or heater system completely off.
