LT1 Trouble!!!!
Old Jun 27, 2006 | 03:41 PM
mike1500's Avatar
Default LT1 Trouble!!!!
Ok folks, my LT1 has betrayed me!
Couple days ago I was cruising home from work, I pulled into my apartment complex. I was slowly cruising in.. Every tiem I drove past a car it sounded like there was a sprinkler on, finally I realized the sprinklers werent on and that it MIGHT be my ccar, so I look at the temperature and quickly park, I WAS OVER HEATING! CRAP! So any ways I had somone I knew come over and check it out, guess it was the waterpump. We replaced it and now the heating problems gone, but im worried that maybe getting hot caused some kind of problem.. I am noticing when I had the hood up last night just checkin to make sure everything was running alrite monitoring the temperature at idle rigght at the middle of the gauge. But it sounds kinda like fluttering should I say, somthing doesnt sound right. Kinda ... like a knocking? But hard to identify since my car knowledge is short, Anyone have any idea on what may of went wrong?
And by the way we found that there was coolant on top of the opti. Sound like the opti here? Or somthing else?
Old Jun 27, 2006 | 03:58 PM
the_merv's Avatar
I would change the Oil, and be real easy with it for a while, and see what it does. Mine threw a Head Gasket, and it was running under 200 degrees, these things can be bitchy...
Old Jun 27, 2006 | 04:01 PM
White 96LT1's Avatar
just dump the oil. it probably has antifreeze in it. also check the oil filter for any metal?
Old Jun 27, 2006 | 04:02 PM
TurboZ28's Avatar
How hot did it get?
Old Jun 27, 2006 | 04:21 PM
mike1500's Avatar
Originally Posted by TurboZ28
How hot did it get?
3/4 and probably alot hotter after It was shut off
Old Jun 27, 2006 | 04:22 PM
mike1500's Avatar
I was thinking of using Seafoam, maybe I should sea foam my **** then change oil?
Old Jun 27, 2006 | 06:06 PM
Charging TA's Avatar
Isnt the stock fan turn on somewhere in the 220s-230s?
Old Jun 27, 2006 | 09:51 PM
Hark_Z's Avatar
160 thermo/early fan tuning cures everything.
Old Jun 27, 2006 | 11:17 PM
camar0corey's Avatar
Yeah the stock fan comes on way late, I wired up my own fan switch, cost you like $5 in supplies to do so. Didn't matter much anyway when my hypertech 160 degree thermostat failed in the closed position! Goodbye head gasket, seperated at the rear of #7 cylinder. After the rebuild a 170 Be cool thermo went in, they are supposed to fail in the open positon.
I always thought that was a stupid design, water pump fails, and to tell you it streams water out of the weep hole, which is above the opti, who approved such a stupid design?
Old Jun 27, 2006 | 11:40 PM
the_merv's Avatar
My fans were setup to constantly run, and I have the AC removed. It runs around 200 at all times, 210 running it at the track. It could possibly have a 160 T-stat in it, it was Hypertech tuned when I bought it.
Old Jun 28, 2006 | 12:43 PM
TurboZ28's Avatar
Aluminum doesn't like heat. If it went too high you might've warped a head.
Old Jun 28, 2006 | 01:34 PM
the_merv's Avatar
How hot do you think it would warp at, like over 250..
Anyone have a Head warp and remember what it was running at?
Old Jun 28, 2006 | 02:18 PM
infinitebird's Avatar
If you mean 3/4 of the gauge that's not really uncommon. Unless it was in the red zone and your fans never came on.
Old Jun 28, 2006 | 03:12 PM
mike1500's Avatar
Does my prroblem sound opti related?
Old Jun 28, 2006 | 03:29 PM
Jditlfm's Avatar
i say change the oil and look for antifreez, the oil will be real watery. If their is should probibly look into a head gasket.
Old Jun 28, 2006 | 09:35 PM
95camaroz28's Avatar
check opti
Old Jun 29, 2006 | 10:16 AM
When my head gasket blew my temp gauge was maxxed out. I had no coolant flow cause the thermostat was closed so of course the fans didn't help in the least.
I'm suprised that constant temps are around 200, is that the average for people? Wiht the 170 themostat I seem to run around 180, same in town cause I flip the fans on as soon as I hit the off ramp. Unless the temp gauge is lying? Or are alot of you guys not running a fan switch?
Old Jun 29, 2006 | 10:24 AM
ZFan88's Avatar
I run a manual fan switch with the stock thermostat. I have the 160t awaiting time for install. Manual switch was the best thing for me as I never let it go over 180. I think it's 180...the first line
Does the knock go away after warm up? GM's tend to have the lifter knock I've noticed and low start up oil pressure
Old Jun 29, 2006 | 03:25 PM
No.
Your problem is likely one of:
thermostat
radiator
water pump
coolant hoses/air in system
improper coolant mix or level
incorrect/too high fan settings
Since you say there was coolant on top of the opti, you may have a leak somewhere.
Old Jun 29, 2006 | 08:19 PM
mike1500's Avatar
Originally Posted by infinitebird
No.
thermostat
radiator
water pump
Yes, the waterpump was broken, but the problems im describing right now, is after replacing the water pump.. Not leaking any more.. Read the first post of mine.
