i need help NOW
Old Jun 28, 2006 | 10:53 PM
streetrod93's Avatar
Default i need help NOW
i'm tired of ****************ing with this one bolt.
the top left bolt on the bellhousing of a 93 z28. is impossible...i've tried impact wrenches, my steroid freak brother, and nothing can get this loose and i'm done fooling with it....who's got any ideas
Old Jun 28, 2006 | 11:21 PM
ellokote5's Avatar
I used a pipe on the ratchet for leverage, and it worked for me.
Old Jun 29, 2006 | 12:08 AM
97z2801ss's Avatar
Big Pipe on a ratchet if possible
Old Jun 29, 2006 | 12:16 AM
urbanhunter44's Avatar
I used an impact gun with a 4 foot extension and a swivel socket on the end. easy peezy.
Short of that.. use the pipe.
Old Jun 29, 2006 | 09:04 PM
James Montigny's Avatar
WD40 , PB Blast, etc ... soak overnight
Then a nice long breaker bar with extensions
Old Jun 29, 2006 | 09:05 PM
Speed Density's Avatar
hashtagBMW
LOL, we had problems with mine too, we used a 2 ft bar on a 12'' ratchet and the bitch broke.
Tony.
Old Jun 29, 2006 | 09:23 PM
zlover129's Avatar
x2
Old Jun 29, 2006 | 09:46 PM
sbcgenII's Avatar
If you are using a bunch of little short extensions buy some extra long ones and see if it helps, You couldn't break it loose with an impact? Was it not lined up right or did it not have enough power?
Old Jun 30, 2006 | 01:03 AM
onebadblackz's Avatar
.....pipe and rachet did mine two days ago and now have to do it again...
Old Jun 30, 2006 | 01:09 AM
-PEPE-'s Avatar
If you ever pull your engine a small slege and a little finesse will free up some future room for removal, don't go crazy on it but it's a PIA because of the angle, swivels don't like that bolt much either. Good luck with it, impact with an extension would be the best if you have one.
Old Jun 30, 2006 | 06:22 AM
94EvilZ28's Avatar
take a torch if you can and heat that bitch up...then try it...it should shrink the bolt a bit...
Old Jun 30, 2006 | 07:37 AM
slowmofo's Avatar
some c4 should get the job done, if you don't have any handy I would use the advice everyone else has said.
Old Jun 30, 2006 | 07:48 AM
Fujimo84's Avatar
+1 heat is key
Old Jun 30, 2006 | 11:57 AM
TurboZ28's Avatar
Definitly slip a pipe over the socket wrench. I've had quite a few bolts that wouldn't come out with a impact gun but would using that method. Also soak it in a ton of PB nut blaster.
