High temperatures...
Old Jul 5, 2006 | 07:42 PM
infinitebird's Avatar
Originally Posted by sdm1234
absolute optimum temperature for the block is 200 degrees, which maximizes combustion efficiency and the air/fuel mixture process, so i don't want to go too far below, like some of you have.
You will almost always make more hp with cooler temps.
GM set the temps high to get better gas mileage, so yeah if you want efficiency, leaving the temps higher is fine.
If you want more power, run the engine cooler.
Old Jul 11, 2006 | 08:34 AM
James Montigny's Avatar
Originally Posted by slagger
you want the longer part down, right?
Yes
Old Jul 11, 2006 | 11:44 AM
94EvilZ28's Avatar
Mine read the same thing...turned out to be a bad gauge...make sure its actually running that high.
