Solid Roller Pushrods-What part number?
Old Jul 2, 2006 | 09:29 PM
mightyquickz28's Avatar
Default Solid Roller Pushrods-What part number?
Anyone have a part number or a pushrod length to use as a guide? Or is there an 'off the shelf' solidr roller pushrod? I guess I have to know if it's a smaller base circle cam (which I don't know at this point since it's a slightly used cam). I have just purchased a custom Cam Motion Solid Roller cam for my new 383 motor. It came with Crane solid roller lifters. Did you solid roller guys end up having to measure for some custom sticks?
Old Jul 4, 2006 | 02:37 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
whats the part number on your lifters, want to know if i have the same ones??
Old Jul 4, 2006 | 03:02 PM
O Holy P's Avatar
Best thing to do is get a push rod length checker and then roll it over to check for geometry & roller travel over the top of the valve.
I've got Crane 11522's with T&D shafties...I'm using Trick Flow chromoly push rods at a length of 7.9".
P
Old Jul 4, 2006 | 03:30 PM
I'll PM the seller and ask if he knows what the crane solid lifter part numbers are. Thanks for the feedback.
Old Jul 4, 2006 | 03:33 PM
pigpen's Avatar
7.9 " here also, w/ T&D shaft mounts, Crower lifters, and Cam Motion solid.
As mentioned, use a push rod length checker.
