I want some suggestions
Old Jul 7, 2006 | 01:19 AM
Kanes2413's Avatar
Default I want some suggestions
I have some money to spend right now and i wanna throw it into the car as I took it to the track and wasnt satisfied. I have a 93 lt1 t/a engine is all stock but have full exhaust, cai and tune. Wat should i do maybe some porting,gears,stall? im NOT going to do a h/c setup now or turbo s/c. Whats a good way to grab alot of power before any of those big setups?( im going with le2 setup sometime in the future fwiw.)
Just wanna hear whats next or some good suggestions!!
Old Jul 7, 2006 | 01:33 AM
harvickgm's Avatar
i would do 3.73 gears, with a girdle for added strength.. a good stall around 3200 and some slicks, and some LCA's... do the suspension and tires mainly... without traction, power is nothing...
Old Jul 7, 2006 | 02:01 AM
LMz28's Avatar
soooo-spen-shun... LCAs, panhards, sway bars etc. i hear those electric water pumps are nice though...and maybe some 1.6 rockers...but i have to agree...suspension is a must.
Old Jul 7, 2006 | 02:26 AM
94z28L's Avatar
suspension for sure, changed the car up nicely or a stall, ive seen a good stall shave .6 off member's et's on here
Old Jul 7, 2006 | 11:35 AM
Kanes2413's Avatar
whats a good stall and im not going to bust rear end anytime soon am i?
Old Jul 7, 2006 | 11:39 AM
infinitebird's Avatar
With an auto you probably will not bust the rear until you have some more power, but there are no guarantees with the 10 bolt.
Old Jul 7, 2006 | 11:45 AM
imnotplutonium's Avatar
how much of a diff. does the panhard rod and torque arm make? those are the last things in my setup and i am not really sure what to expect. obviously a bumpier ride huh?
Old Jul 7, 2006 | 11:50 AM
panhard helps a lot with cornering stability
torque arm will help you plant the tires better and get a better 60'
Old Jul 7, 2006 | 12:39 PM
slowmofo's Avatar
Stall, gears. Your not going to make enough power yet to spin DR's
With a stall+ Street tires though thats another story. My car cut 1.7's on the stock suspension, with MT Dr's, dead hooking.
Old Jul 7, 2006 | 01:00 PM
Fbody4Ever's Avatar
Skip the gears for now and do a good stall (such as Vigilante (my preference) or Yank), and some suspension mods. You may not want/need gears with the stall. Lot better bang for buck with the stall too. With the 93, I'd do a 3200 stall right off the bat. Anything less than 3-3200 is a nice improvement but will leave you wanting more.
As others said, LCA's, relocation brackets (lowered or not) and PHR while you're at it are good mods too.
M/T DR's after that and you should have a NICE gain at the track and a it'll be lot more fun to drive on the streets.
The stock 10 bolt is always a craspshoot but with your setup it should be more than fine. Then again, **** happens. But should be fine.
Old Jul 7, 2006 | 01:09 PM
Speed Density's Avatar
hashtagBMW
I would just do a stall and gears. As slowmofo said you can do very well on stock suspension.
Tony.
Gloveperson's Avatar
Nitrous
Old Jul 7, 2006 | 03:18 PM
slowmofo's Avatar
Originally Posted by Gloveperson
Nitrous
Quickest way to make good power and stay streetable!!
Old Jul 7, 2006 | 04:09 PM
Kanes2413's Avatar
damn i just bought all new tires i rather not buy DR's atleast not right now i dont plan on going to the track enough right now to make them worth there price. And no one has mentioned porting at all? is it pointless on the stock tb,intake manifold and heads to port them ive heard it helps alot but wasnt sure if it was a h/c setup or stock?
Old Jul 7, 2006 | 05:03 PM
slowmofo's Avatar
Its not worth it IMO to pull the heads to do porting, unless your really gonna do some porting, and bigger valves ect... If you were gonna have someone like loyd port them then sure its worth it, but them you would need a cam to take advantage of the heads, then a stall to take advantage of that.
With a stall you can have fun with street tires, you just will never see the full potential of what your car can do with it.
I cut a 1.85 60 with just a stall, 3.42 gears, and a dynomax muffler. Best I could get with a street tire was a 1.96 and that was still coming out soft. Most of the time it was 2.0+ on a street tire.
By Brett Foote | 2026-06-04 05:00:17
