header bolts?
Old Jul 13, 2006 | 08:37 PM
Camaro94SS's Avatar
Default header bolts?
Do i need to get header bolts when installing LTs?? and where can I get some from?? Also i need to know a reliable online source to order OEM header gaskets and 02 exstensions....anyone know a good place to order from?
Old Jul 13, 2006 | 08:41 PM
Starz T/A 17's Avatar
most everyone reuses the old header bolts, as far as the gaskets probally GMpartsdirect, fred beans, or just goin to your local GM dealer will be the best bet for OEM gaskets GOOD LUCK
Old Jul 13, 2006 | 09:09 PM
TORCHD 02 TA's Avatar
it would be a good idea. Get stage 8 locking header bolts. that way the headers will not come loose
Old Jul 13, 2006 | 09:15 PM
Luna's Avatar
I would have reused the stock bolts but my pacesetters came with new ones. I dont think there is any need to spend a fortune on expensive header bolts.
Old Jul 13, 2006 | 09:33 PM
blkZ28spt's Avatar
You can reuse the stock bolts. Clean them up a little if you like, and use ani-seize (sp?).
You can get the gasket from any dealer and I'm sure most of our sponsors could get them to you as well.
Old Jul 13, 2006 | 11:20 PM
TheBlurLS1's Avatar
That's what she said...
Are you installing these in an LT1 or LS1? I noticed you already started a different thread to ask about O2 extensions for an LT1. You can ask more than one question in a single thread ya know.
Old Jul 13, 2006 | 11:54 PM
Camaro94SS's Avatar
LT1....thanks
Old Jul 14, 2006 | 12:00 AM
Camaro94SS's Avatar
I have pacesetters and got them from TSP, but i didnt get any header bolts....where did you get your headers from?
Where can i get headerbolts at anyone...and no one has still told me where to get 02 extensions....i plan on just getting the gaskets from a local GM dealer i guess since eveyrone has pretty much said that
Old Jul 14, 2006 | 12:12 AM
TheBlurLS1's Avatar
All these guys are giving you advice assuming you had an LS1. Pacesetter LS1 headers come with new ones but we usually reuse the stock bolts. This may not be the case with LT1's.
I'll move your threads to the LT1 section where you may get more help.
Old Jul 14, 2006 | 12:28 PM
Camaro94SS's Avatar
http://www.thunderracing.com/catalog...vid=4&pcid=301
WHich ones should I buy for an LT1 from there?Im not too sure ont he length, or does that not matter?
Old Jul 15, 2006 | 11:47 AM
Nite_Hawk's Avatar
I ordered my Pacesetter's from Texas Speed and they came with new header bolts.
Old Jul 16, 2006 | 04:26 PM
Bawls's Avatar
I bought the Breslin locking header bolts just for safe measure. Price is kinda high for some bolts, but it's all good.
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 17, 2006 | 10:11 AM
30696bird's Avatar
You bought intake bolts for the exhaust??? I also bought Breslin. BY FAR worth every penny to me. It makes the install ALOT easier. The reason install is alot easier is because they're 12 point and you can get the boxed end of the wrench on eaaaaasy. I could not find the right ones on summit or jegs so here's breslins contact #'s. Call them and ask for part# 600-101, those are 3/8 - 16x1" long, there are 12 of them. Hope that helps if you go that route.
BTW......those intake bolts will work too (they're the same dementions. ) But the 600-101's are stainless and will NOT rust. better choice if you want the looks or if you ever had to take them out.
