biggest lt1 cam
I can't wait for this custom cam fad to be over . . .
Mike
They make plenty different grinds of cams to work with just about any set up out there. I have built quite a few small blocks and have made great power with cams listed in Summit from Comp cams and Lunati. Of course the cam has to match the set-up but damn, a custom one ain't gonna be that much different! I can see if it's a forced induction motor but I'm referring to a mostly stock or N/A set-up. I guess you really think that Custom set-up is really going to be the fastest thing out there don't you.
now stock bottom end dynoing over 400 is pretty common, plus they are 10-20 more foot lbs of torque then an off the shelf grind.
if your just looking at lift and duration at 500 your not seeing the whole picture. look at a solid cam vs a hydrolic. if they both had the same lift and duration at 500 the solids still going to make more power and even idle better.
i swapped out my 306 cam with something that had less duration and just a little more lift and i made 11 more hp and 15 foot lbs of torque up the whole rpm band... not just peak numbers. that was using the same ported heads, same valve springs, same everything. i put a better set of ported stock heads on and got another 20 hp.
The most powerful NA LT1 that I know if is a local guy named Tim. He made 475 rwhp with an LT4 intake, ported LT4 heads, stock bottom end, and an off-the-shelf SBC solid roller cam.
We don't ALL NEED custom grind cams.
Mike
Sounds like your the ******* idiot hodge. I seriously doubt I could gain much more HP from a custom cam, if you know your set-up and know what you want then there are plenty of off the shelf cams that'll do the job. The guy asked for some recommendations for a cam size, not the Oh you need a CUSTOM cam comments. I swear, guess you damn towel heads are ignorant as hell
Mike
My point exactly, THANK YOU!!!
Comments like this make you look "Ignorant as hell"
Do you honestly think I give a damn? All that BS people post in here is uncalled for, he pissed me the hell off being a smartass so I let him know what I thought about it. This is a place for tech advise not a bunch of BS bitching so drop it and get back on topic. It's pathetic that the original post still hasn't been addressed yet, he was asking for a cam recommendation so let's get it back on topic and help the guy out a little.
So, I'm not that familiar with LT1's but a cam such as a CC306 should be plenty. If your just looking for a good sounding cam the LT4 hot cam sounds really mean and makes decent power also that GM 847 seems to be a pretty hot grind. I bought the CC503 cam for my mostly stock LT1, after hearing a sound clip I was impressed with the idle and from what I've read it seems to be good for 350 RWHP. Don't go with too big of a cam though cause not only will you lose power, it will be nearly impossible to tune correctly.
Yeah I edited my post because it was a little extreme. I did give him advise, it all depends on what he wants. What part of that last post did I tell him what to get? BTW, I don't have a line to cross. I'd give a damn less what any of you think, play with fire you get burned. Simple as that...
The comments I said weren't directed torwards a group of people, they were for you and you only. I can't figure out what part of that post I made declaring my point would make you call me an idiot and tool. Seems like your the tool, maybe all those gay sailor games ya'll play out there have messed you up. I don't give a **** who I offend, people in general **** me off. Tell you what, I'll let you be the little bitch and have the last word. Fire away, the floor is your's....
I'm not playing these internet bad *** games, you got flamed for being a retard and now your crying about it. Go cry me a river sailor boy
You are really looking like an *** now..... You really are that stupid to think what you posted was "flaming someone for being retarded"?
