Le2
Old Jul 18, 2006 | 02:03 PM
95FbFormula's Avatar
Default Le2
Were can i get the LE2 head and cam packages. I cant find the site??
BizZzatch350's Avatar
Moderator
http://eportworks.com/
Old Jul 18, 2006 | 07:15 PM
THX
Old Jul 18, 2006 | 09:27 PM
I forgot to add I want to build the bottom end up to hopfully all forged rotating assembly if i can among other things I will be adding. I wanted to ask if this would be a good Idea going with the LE2 heads/cam or should i save or $ and go cast. I dont plan on using Nitrous or making anymore power than what I will have after heads/cam and block build so is it even worth going to forged crank, pistons, ext.
Old Jul 18, 2006 | 09:47 PM
MaxFubar's Avatar
it probably wouldn't hurt to go ahead and get the stronger forged rotating assembly. Might as well, it'll give you peace of mind when you wind that thing up to 6000rpm+.
Old Jul 18, 2006 | 10:04 PM
Old SStroker's Avatar
You might ask Lloyd hisself. You'll find him easy to talk with and with so many folks going thru exactly what you are, he may have some good recommendations for you as to how far you need to go with your shortblock.
Old Jul 18, 2006 | 11:30 PM
OK thx also would my block be ok to use it has about 74K its a 95 so i would like to just use it if i could.
