Still overheating problems....
Old Jul 20, 2006 | 01:59 PM
studlybilly's Avatar
Default Still overheating problems....
Ok this car is pushing its limits. Specs are 94 Z28 with 97 T/A motor, around 40k on the clock and a 3500 stall. I put a 180 thermo in it about 6 months ago in hopes and thinking it would resolve the problem. Less than a week ago I installed a new CSR Electric water pump. This seems to keep things cool for a little while, but eventually it creeps up to 230-240'sh or at least that's what the gauge is reading. It creeps up slowly like with highway speeds, then when you come to a stop the gauge doesnt seem to go up or down. So now with the EWP we'll turn the key to the start position to let the pump and fans cycle and cool the damn thing down. I DO have a fan switch and at this rate we leave them kicked on high at all times. It does take a descent bit of driving before it starts getting above 210. Any ideas Maybe put a new 160 thermo in there from pep girls or something?
I also noticed the air scoop under the front end of the car was starting to come loose and looked a little bent up from to many curb confrontations, could this be fuxoring things?
One of the things that strike me as odd with the Stock temp gauge. Is with the car running persay it's reading 210. When I turn the car off then put the key back to the "start" position to let the fans and Water pump cycle, it drops like 10'sh degree's. I know the stock temp gauges are duds to begin with but that makes no sense.
Old Jul 20, 2006 | 02:29 PM
lt197formula's Avatar
Your air damn could easily be making the difference, try replacing it.
Old Jul 20, 2006 | 02:31 PM
MrBill97396's Avatar
Air Damn replacement and temp sensor try that out in that order.
Old Jul 20, 2006 | 02:47 PM
Just to confirm, the air dam itself is merely one piece right? I keep reading about "Air Dam Supports" sounding like a factory part, I don't think I have anything else attached to the air dam itself. It's merely bolted to it's little cross member just under the radiator, and other then that it's just danglin' LOL
Now by temp sensor do you mean the sending unit for the stock gauge? Will that make it accurate again or accurate enough or will I still need to pop an autometer in there?
Old Jul 20, 2006 | 03:00 PM
streetwarrior96's Avatar
I have the same problem as you, EWP, coolant nice and full, 160 thermo, programmed fans, clean radiator (had it flushed). I'm just gonna break down and buy one of those becool radiators. temps here in south texas has been over a 100 the past month and 1/2.
Old Jul 20, 2006 | 03:12 PM
Look here
Old Jul 20, 2006 | 03:15 PM
Better yet hit this site up, it is a great help
shbox.com
 Michael S. Palmer
Old Jul 20, 2006 | 03:28 PM
I'm being told the sensor I need to replace for the gauge is on the drivers-side cylinder head? Between #1 and 3 exhaust ports right on the side.
Old Jul 20, 2006 | 03:43 PM
Old Jul 20, 2006 | 08:29 PM
rkinney's Avatar
I am having this same problem with the exception that I have a 160 stat. I drive home from work, and it runs normal temp that it always has with the 160 stat. If I get on the car, starts to heat up and does not want to cool back down. Go home and park the car, come back out and drive it, and the low coolant light comes on. Has done this the last three days. I installed a csr water pump a few months back also. I know the low coolant sensors are known to act up, but it only comes on after I shut the car down then come back out and drive it. Radiator is full as well as the overflow. I am wondering if this EWP is just not working as efficient as the stock unit. I just don't understand why the low coolant light comes on only after I shut the car down and then drive it again. Seems like it only wants to heat up right after I get on the car. I am in the Dallas area, and I know it is hot as hell, but this car has never run this hot with the 160 stat in the summer until I have had this EWP. I guess it is possible I have other issues, but the radiator is only about 6 months old and I flushed the system with the radiator swap.
Old Jul 21, 2006 | 11:06 AM
My low coolant light comes on frequently as well. System still full of water with no air bubbles or at least to what I can tell.
Old Jul 21, 2006 | 01:07 PM
JUICED96Z
Guest
Posts: n/a
Sure the fans are coming on? My car did the same thing and it was a bad fan fuse. The fuse looked fine untill you but an ohm meter on it and it was bad.
Old Jul 21, 2006 | 02:39 PM
02blutb's Avatar
bleed the lines of air. there is a small screw on the stat. also might wanna get the radiator flushed because if the fans are working its most likely your radiator
Old Jul 21, 2006 | 04:47 PM
azmarkus's Avatar
Default Radiator cap
You might want to check the radiator cap as well; mine was running a little too warm for comfort 220-240, picked up a new radiator cap and it's back to normal now...as normal as it can get here in Phoenix, 115 today.
Old Jul 25, 2006 | 08:27 AM
Well tightened up the front air dam. Put a new temperature sending unit on the head. GF drove the $hit out of it yesterday and she said it stayed just under the half-way mark, with a 180 t-stat I can't complain. So maybe the gauge sending unit was at fault. I'm going to use some of that take home radiator flush stuff to make sure everything is clean in there. So far so good, thanks guys.
Old Jul 26, 2006 | 10:56 PM
My25thTransAm's Avatar
Yeah, I live in Lubbock,Tx and my coolant light comes on after about 25 minutes of driving and the won't get much colder than the 1/2 mark on the thermostat
Anybody else see the pattern of everyone's overheating problems being that we are having hot *** weather in our particular states? Damn global warming.
