Get ur done! New dyno #'s
Originally Posted by Honda Hunter
That's odd. some people reported the same issues with the deltech. The conclusion was it just doesnt work on all cars. BTW, i didnt accuse you of anything. I was just curious as anyone should be.
Never looked much into the Delteq, never cared for the 4-coil setup, but have heard mixed stories on it, same as LTCC.
Originally Posted by blkchevyz
what a tease... comes on here posting is numbers then doesnt tell us the specs
don't have a home connection, so it's in between meetings at work, etc that I get online....takes a deep breath....
LME built Callies forged solid roller 396, 4-blt main, custom CamMotion grind, custom matched JE/Wyseco pistons, Callies H-beams & crank, custom ported AFR-210s maxed by LME, Ferrerra valves, Nextek SR springs, Cometic head gaskets, custom ported LT4 intake, 42lb SVOs, 58mm TB, Walboro 255lph intank (for another month), Canton blueprinted oil pump & pan, Kooks SS 1-3/4 - 1-7/8" stepped race headers & custom Kooks SS ypipe w/dual QTP SS 3" cutouts, open Borla catback, 12-blt, 33-spl Moser axles, c-clip elims, 4:10s, 700hp Eaton posi, CompEng weld in supframes, BMR TrakPak tqarm, BMR Kmember, BMR upper/lower A-arms, QA1 12ways all around, T-56 Rebuilds built T-56 (viper hardned gears, syncros, Microtek'd, etc), McLeod twin disc w/billet steel McLeod fw.
hoping 500rwhp with good driving will give me mid 10s.
Great numbers! You should be well into the tens NA. From the graphs, guess that is a manual trans? You should be very pleased. Btw, all I have ever used was a stock GM Optipsark. Most opti problems are self induced.
Congrats!
Congrats!
That is awesome, my hopes are starting to rise for my setup now. 396 LT4, with the AFR 227 LT4 heads, big *** custom cam, running close to almost everything you are. I'm using the monoblade TB instead, and a few different suspension parts, and a 9" instead of a 12-bolt. I would love to see you cam specs and compare them with mine, and see how far off we are. I will be dyno'ing mine next week if it's running good. Oh, and also have the t56 that is going to be rebuilt, with all you have except the hardened gears.
Originally Posted by stroked30th
Excellent job
Wish I could get down in some better air. My LT4 headed 385 would be close to some of those numbers.
Good luck, Ed
Originally Posted by Ed Wright
I tune for a couple of shops in Denver, and their corrected dyno numbers are as high as cars down here. At the track you would certainly run quicker at sea level, but your dyno numbers would not likely improve. Mine makes 514 SAE/522 Std through an unlocked 4400 RPM converter, so he has enough power to run well into the tens, close to 130 mph NA. That is an easy nine second car with a little nitrous. Mine picks up right at 1/10th of a second per 1000' DA improvement, that might give you some idea what your car could run at sea level.
Good luck, Ed
Good luck, Ed
I went to a March PSCA race in pheonix, but battled an ignition miss all weekend. Car picked up .5 in the 1/4 w/ miss; 11.5 -11.6.
1/10th per 1000 DA sounds just about right to me.
This thread is the real-life tangible evidence that backs up all the testaments that are found in the "Why build/keep an LT1?" thread.
Outstanding #'s man. Way to keep the Opti-Warriors in the game.
Congrats!
Congrats!
I met some cool folks from here out their tonight that took some good videos, I'll post em up when they email em.
Thanks man, well tonight hit HRP and my best run was 11.6 @121 launching @4500 rpm it finally quit bogging, my crappy tire gauge think the tires were around 17psi, I borrowed a good one and got it down to 12psi and that launch was crazy, car was all over the place, I let out in 3rd gear finally. bumped it back to 17psi and it likes that. Time for some real drag tires. Think I'll bump the rear QA1s up to 10 and it likes 2 on the front. It ran good for me being 2 yrs rusty. Finally got my R/T down to .003 was the best with a 1.7 60'. Gotta lotta work to do on my skills though, I would like a 1.5 60'. I need to lose weight too, she weighed in @3570 me in it with a 1/2 tank.
Good luck, Ed
