Best way to do a huge burnout M6?
9-Second Club
When I ran a stick car I always used 3rd gear. Get a line lock, like the other guys said. Roll them over the water, Set the line lock just past the water box, put it in 3rd, and drop the clutch at 5000. That will heat them up pretty quick. Once I see smoke in the rear window, I let the line lock off. No need to sit there for almost a full minute like you some guys doing. The faster you spin them, the quicker they heat up.
Good luck, Ed
Good luck, Ed
9-Second Club
Originally Posted by firebirdformulaTA
starting in 2nd will allow higher RPMs which means more smoke / faster spinningtires
im a double clutcher myself
imo its allot safer and less wear and tear on your car(done correctly) when i burnt off my old tires i started the burnout in 1st, hit 2nd, 3rd and 4th but i stoped ther out of fear of blowing up the tires
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by ToxicTA
I prefer to be a little different.
Burnout M6
Burnout M6
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
hey man your car looks and sounds sick
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#32
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#33
for a great m6 burn out, just add more power.
here is a burnout. http://www.ls1speed.com/movies/jim.wmv
#36
Originally Posted by bww3588
your car is going to look nice when some brake fluid splashes up on your paint and eats it.
#37
Originally Posted by donkey mule
Bww3588 , He asked a question about the best way to do a burnout. I am not advocating this or any burn out for that matter but if you are going to do one you mine as well make it nasty as can be! Oh by the way, I did this on a regular basis and the brake fluid never ate through my paint.
