AZM Monoblade question?
Old Jul 22, 2006 | 02:21 AM
-PEPE-'s Avatar
Question AZM Monoblade question?
Ordering an AZM Mono soon and have a question. My LT4 intake was custom ported all the way through including matchup for a 58mm TB. But when I go mono what happens to the bottom part middle of the intake? Believe it's something for the IAC on the bottom of the TB but honestly not sure. Am I supposed to leave that part alone. I know I can trim the top off but not sure if I leave the bottom alone. Thanks for any advice.
Old Jul 22, 2006 | 09:30 AM
Turbo_6's Avatar
When you remove the divider between the throttle bores, the IAC inlet will have to be ground down so it's not obstructing airflow. Just make it even with the bottom of the throttle body opening and you are good to go. When I was running an LT4 intake, I just sealed mine off to prevent oil/sludge from getting in there. The monoblade has its own IAC built in as you'll see when you have it in hand. The downside is there isn't individual IAC openings in each runner like you have running the factory IAC and a twin bore throttle body but there is no way around this with the monoblade. It worked fine on my solid roller when I was using it.
Old Jul 22, 2006 | 10:45 AM
TwoFast4Lv's Avatar
What he said
That AS&M Mono is a work of art...I have one also just not on the car
Old Jul 22, 2006 | 11:39 AM
-PEPE-'s Avatar
Turbo6 thanks man, exactly what I wanted to know, apprecdiate the pics looks like you have it flowing good there.
Ellis...I know someone looking for a monoblade ... c'mon man...I'll trade you a "BRAND NEW HOLLEY FOR IT"...sent my holley back and think they'll be replacing it with a new one.
Originally Posted by TwoFast4Lv
Old Jul 22, 2006 | 12:36 PM
blind527's Avatar
Would you guys recommend getting a 52mm or 58mm TB with bolt ons and a 150 shot? Will it help my numbers at all? I thought about getting mine ported, but I don't know, or if I should just get a new one.
Old Jul 22, 2006 | 12:55 PM
-PEPE-'s Avatar
don't bother porting, 52 with boltons is ideal, but 58 won't hurt anything and you'll be good to go for future power plans. Just my opinion.
Old Jul 22, 2006 | 01:57 PM
firebirdformulaTA's Avatar
dont mean to steal the thread i tried searching... but what is a monoblade...?
Old Jul 22, 2006 | 03:13 PM
BizZzatch350's Avatar
Moderator
Its a throttle Body.
Old Jul 22, 2006 | 03:20 PM
blind527's Avatar
Mono=1 so monoblade is a 1 plate throttle body, instead of 2. I think he knew it was a "throttle body".
Old Jul 22, 2006 | 06:01 PM
TwoFast4Lv's Avatar
1350 CFM of pure over kill
UNLESS the rest of your combo is over kill to go with it
Old Jul 23, 2006 | 01:25 AM
Wait so what is the advantage to the monoblade??
Old Jul 23, 2006 | 02:44 AM
harvickgm's Avatar
more air for bigger engines.....
Old Jul 23, 2006 | 11:40 AM
Turbo_6's Avatar
No problem dude. The LT4 intake flowed OK. Now this on the other hand...flows good. I'll hopefully find out this week just how good.
Old Jul 24, 2006 | 03:30 PM
Azthrei's Avatar
I've got the monoblade running on my setup as well, another 396 LT4 solid roller with a big *** cam. Hopefully I put down numbers similar to Brettinator here. I'm just looking for low 12's at this altitude myself, 4500 and higher depending on the weather.
Old Jul 24, 2006 | 05:06 PM
pigpen's Avatar
I'd heard some people having problems with the return spring not being stout enough on the monoblades. Anyone here had those issues, or has ASM addressed the problem and fixed it?
Old Jul 24, 2006 | 07:08 PM
-PEPE-'s Avatar
concern I have is on an n/a application will this elbow restrict airlfow, on a boosted application it'd be fine, but otherwise restrictive. But I'm also kicking around the idea of the SuperVic with a 1650cfm 4barrel style TB, custom carbonfiber airclearner setup on this 3" SS hood and as I've learned today going speed density vs mass air flow with a FAST pcm.
Old Jul 24, 2006 | 11:08 PM
Turbo_6's Avatar
I never had a problem with my monoblade and the throttle sticking.
Brettinator, I also toyed around w/ the idea of a 4bbl TB but didn't want a conventional aircleaner under my WS.6 hood and wanted to keep the MAF for now. I can't see the elbow being a major restriction, at least compared to the LTx style manifolds but we'll see. My setup is basically a max effort street car that may spend 10% of the time on the track. I'm very interested in hearing about how your project progresses so keep us posted. I'm hoping Ill be posting up some new dyno graphs of my own by next week.
