removing intake
Old Jul 24, 2006 | 09:45 PM
transambandit's Avatar
Default removing intake
is there a write up anywhere for removing the intake for an lt1? i think im going to have to pull it partially out to get to the EGR so i can block it off.
Old Jul 24, 2006 | 09:56 PM
-PEPE-'s Avatar
checkout shoebox.com his website has it I'm pretty sure. It's not a bad job really and you'll get to reseal your intake out back where they used to be prone to oil leaks from GMs shabby seal job.
Old Jul 24, 2006 | 10:04 PM
engineermike's Avatar
Pulling the intake on an LT1 is cake. No distributor or water passages. Pull all the wiring, hoses, TB, alt bracket, then the 12 bolts and it's off!
Old Jul 24, 2006 | 10:13 PM
shoebox.com?
Old Jul 24, 2006 | 11:06 PM
droptop z's Avatar
http://shbox.com/ci/cam_removal.html
Old Jul 24, 2006 | 11:49 PM
Vettetech81's Avatar
Exactly... nothing is hard just time consuming... If you enjoy working on your car then who cares.. have fun it all comes apart and goes back together...
-=Rick
Old Jul 25, 2006 | 12:13 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
i did mine with the intake on, it wasnt that hard, used ,i believe, a 1/2" wrench, no need to pull the intake to do that.
Old Jul 25, 2006 | 01:25 AM
95FbFormula's Avatar
wouldnt doing this set off the ses light without a tune to delete it. If not i will probably do it to my 95
Old Jul 25, 2006 | 02:10 AM
Bawls's Avatar
Same here. No need to pull the intake. On my 94 it didnt throw a code untill I pulled the solenoid off the wiring harness.
