5 pin 700r4 plug
Old Jul 28, 2006 | 08:28 PM
monster7's Avatar
Default 5 pin 700r4 plug
does anyone know where i can get a plug that plugs into a 93 tranny. its the 5 pin round pin that plugs into the trans. I need the plug and if possible a little wire off it so i can tie into it. There are no new camaros in the j-yard near me. Or does someone happen to know the part number for it.
Thanks
Old Jul 28, 2006 | 08:44 PM
monster7's Avatar
found it myself i think
P/N 24502513 - Switch Kit, GM instruction sheet (source for this page), 4 and 5 pin TCC connectors, Pin Extraction Tool, TV spring, fourth gear clutch switch (P/N 8683502), and 2 small GMPP decals.
24502513 - Transmission Performance Kit for 4L60 & 700-R4 Automatic Transmission
Performance enthusiasts who prefer automatics will be interested in this new installation kit for Turbo Hydra-matic 4L60 four-speed transmissions originally installed 1992 - 1993 Corvettes and 1993 Camaros and Firebirds. This kit adapts the 4L60 automatic transmission for use in early-model computer-controlled and non-computer-controlled vehicles such as bracket racers and off-road trucks. It can also be used when replacing a 700R4 automatic with a 4L60 transmission. The kit includes an instruction sheet, a throttle valve spring for carbureted engines, a normally closed Fourth gear clutch switch and a wiring connector for the torque converter.
Technical Note: This kit can be used on 700R4 or 4L60 automatic transmissions.
$45.74 from sallee/gilbert chevy
